Washing Machines Logo
Question about Maytag Performa LAT2500A
What is the qubic ft.
Posted by kitchende635 on
Anonymous
  • 10,515 Answers
1 Cubic Foot = 28.3168466 Liters
Regarding the exact definition, you could refer to :-
http://www.ehow.com/about_4672014_what-cubic-feet.html
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 22, 2011
Please can you help with all the torque settings for the cylinder head on Hyundai Accent 1.5 1995"
Nissan Frontier, Xterra 1998-05
Torque Specifications
Fig.
TORQUE SPECIFICATIONS
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1998 2.4 (2389) KA24DE
1A Step 1: 22 ft. lbs.
2B 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
4C The cylinder heads and the lower intake manifold are installed together
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1999 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 3.3 (3277) VG33E
1A The cylinder heads and the lower intake manifold are installed together
3C Step 1: Tighten the cylinder head bolts to 22 ft. lbs.
4D Step 1: Tighten the connecting rod bearing bolts to 10-12 ft. lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1998 KA24DE
1- Step 1: 22 ft. lbs.
2- 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
3- The cylinder heads and the lower intake manifold are installed together
4- 10-12 ft. lbs. +60-65 degrees
5- Step 1: 72 ft. lbs.
6- Step 1: bolts 11-22 19 ft. lbs.
7- Step 1: 20 ft. lbs.
8- Step 1: 31 ft. lbs.
9- 83 inch lbs.
10- Stud bolt: 11 ft. lbs.
11- Step 1: 72 ft. lbs.
12- Bolts: 17-24 (M8) 16 ft. lbs.
13- Step 1: 33 ft. lbs.
14- Intake manifold collector:
15- Intake manifold:
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1999 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2000 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2001 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2002 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2003 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2004 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2005 QR25DE VQ40DE
9- 83 inch lbs.
Main Bearing Torque Sequence
Fig. Main bearing torque sequence-2.4L engine
Fig. Main bearing torque sequence-2.5L engine
Fig. Main bearing torque sequence-3.3L engine
Fig. Main bearing torque sequence-4.0L engine
tip
Small Block Chevy V8 267, 305, 327, 350, 400 cid.
Bolts or Parts Lube or Sealer Torque to: 7/16 Main Caps (2 bolt) Engine Oil 70 ft-lbs. 7/16 Inner Main Caps (4 bolt) Engine Oil 70 ft-lbs. 7/16 Outer Main Caps (4 bolt) Engine Oil 65 ft-lbs. 3/8 Outer Main Caps (4 bolt) Engine Oil 40 ft-lbs. 18436572 The firing order Small Block Chevy V8 3/8 Connecting Rod Bolt Engine Oil 45 ft-lbs. 11/32 Connecting Rod Bolt Engine Oil 35 ft-lbs. Cylinder Heads
Engine oil
(blind hole)Sealer
(water jacket)
65 ft-lbs.
Rocker Studs (screw-in) Engine Oil 50 ft-lbs. Oil Pump Engine Oil 65 ft-lbs. Oil Pan Engine Oil 12 ft-lbs. Cam Sprocket (upper gear) Thread Locker 20 ft-lbs. Timing Cover Engine Oil 6 ft-lbs. Intake Manifold
(Cast Iron Heads)
Non- Hardening Sealer 30 ft-lbs. Valve Cover Engine Oil 3 ft-lbs. Exhaust Manifold Anti-Seize Lubricant 25 ft-lbs. Spark Plugs No Lube or Sealer 20 ft-lbs. Flex plate (Automatic)
Flywheel (Clutch)
Thread Locker 60 ft-lbs. Clutch Pressure Plate Thread Locker 35 ft-lbs. Center bolt
(Harmonic Damper)
Engine Oil 60 ft-lbs. Bell housing
(Transmission to Block)
Engine Oil
  • 25 ft-lbs.
on Jul 17, 2010 • 1985 Chevrolet Chevy
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Torque spec's for the fly wheel
Memory battery yaesu ft 26
Je cherche un chargeur pour mod?les de radio YAESU FT-26, FT-76, FT-415, FT-416, FT-530, FT-815, FT-816, remplace les mod?les de batterie FNB25, FNB26, FNB26S, FNB27 , FNB27S
Pierr
[email protected]
2answers
Rebuilding 4.2 v6 ford need torque spec for main bearing
V8 Engines Component Torque Camshaft Sprocket Bolt 40-45 ft. lbs. Camshaft Thrust Plate-to-Engine Bolts 9-12 ft. lbs. Crankshaft Pulley-to-
Vibration Damper Bolts 35-50 ft. lbs. Cylinder Head Bolts All Except 1993 Flanged Bolts Step 1 55-65 ft. lbs. Step 2 65-72 ft. lbs. 1993 Flanged Bolts NOTE 1 Exhaust Manifold Bolts All Except 1993 HO Cobra 18-24 ft. lbs. 1993 HO Cobra 26-32 ft. lbs. Flywheel/Driveplate-to-
Crankshaft Bolts 75-85 ft. lbs. Intake Manifold Bolts Note 2 Upper Intake Manifold-to-
Intake Manifold Bolts 12-18 ft. lbs. Main Bearing Cap Bolts 60-70 ft. lbs. Oil Filter Insert-to-Engine Adapter Bolt 20-30 ft. lbs. Oil Pan 1979 Step1 Large Bolts 11-13 ft. lbs. Small Bolts 7-9 ft. lbs. Step 2 Large Bolts 15-17 ft. lbs. Small Bolts 10-12 ft. lbs. 1980-87 9-11 ft. lbs. 1988 and up 6-9 ft. lbs. Oil Pick-up Tube-to-Main Bearing Cap Nut 22-32 ft. lbs. Oil Pick-up Tube-to-Oil Pump Bolts 1979-87 10-15 ft. lbs. 1988 and up 12-18 ft. lbs. Oil Pump Bolts 22-32 ft. lbs. Rocker Arm Fulcrum Bolts 18-25 ft. lbs. Thermostat Housing-to-Engine Bolts Through 1987 9-12 ft. lbs. 1988 and up 12-18 ft. lbs. Timing Chain Cover Bolts 12-18 ft. lbs. Valve Cover Bolts 10-13 ft. lbs. Water Pump Mounting Bolts 12-18 ft. lbs. NOTE 1 Step 1 Tighten bolts in sequence to 25-35 ft. lbs. Step 2 Tighten bolts in sequence to 45-55 ft. lbs. Step 3 Tighten bolts in sequence an additional ¼ turn. NOTE 2 Step 1 Tighten bolts in sequence to 23-25 ft. lbs. Step 2 After assembly, retorque all bolts in sequence to 23-25 ft. lbs.let me know if this helps and how about a rating.
How many oms for the starter and fan relay on 1991 Cherokee Laredo
Starters are measured in the amps they draw under load (while turning the engine over). General rule of thumb is an amp per qubic inch of engine displacement. For instance, a Chevy 350 V-8 should pull about 350 amps cold cranking. A 150 cubic inch 4 cylinder should pull 150 amps. Disable the ignition system so the engine can not start during test. Ohms generally do not change except if there is an open curcuit (infinity ohms). You did not list the problem that is leading you to troubleshoot this way. If the starter is off the car, many parts houses (AutoZone) will test for free. Ray (garage owner)
5helpful
2answers
Torque Specs for Head Bolts on 1997 GMC Sierra V8 5.0 Vortec?
.0L Torque Specs Belhousing to engine bolts 28-38 ft/lbs Camshaft sprocket bolt 40-45 ft/lbs Camshaft thrust plate to engine block bolts 108-144 in/lbs Crankshaft pulley to vibration damper bolts 35-50 ft/lbs Cylinder head bolts -1979-1992 --Step 1 55-65 ft/lbs --Step 2 65-72 ft/lbs -1993-up --Step 1 25-35 ft/lbs --Step 2 45-55 ft/lbs --Step 3 75-85 ft/lbs Differential shaft lock bolt 15-30 ft/lbs Driveshaft U-joint to pinion flange bolts 70-95 ft/lbs Exhaust manifold bolts 26-32 ft/lbs Flywheel mounting bolts 75-85 ft/lbs Front engine mount nuts 72-98 ft/lbs Intake manifold to head bolts --Step 1 96 in/lbs --Step 2 16ft/lbs --Step 3 23-25 ft/lbs Intake manifold (upper intake to lower) 12-18 ft/lbs Oil filter insert to engine block adapter bolt 20-30 ft/lbs Oil pan mounting bolts -1979 --Step 1 (Large bolts) 11-13 ft/lbs --Step 1 (Short bolts) 7-9 ft/lbs --Step 2 (Large Bolts) 15-17 ft/lbs --Step 2 (Short Bolts) 10-12 ft/lbs -1980 to 1987 9-11 ft/lbs -1988 to 1993 6-9 ft/lbs -1994-up 110-144 in/lbs Oil pickup tube to main bearing cap nut 22-32 ft/lbs Oil pickup tube to oil pump bolts -1979 to 1987 10-15 ft/lbs -1988-up 12-18 ft/lbs Oil pump mounting bolts 22-32 ft/lbs Pinion bearing preload 8-14 in/lbs Pressure plate to flywheel bolts 12-24 ft/lbs Rocker arm fulcrm bolts 18-25 ft/lbs Spark plugs 7-14 ft/lbs Timing chain cover bolts 12-18 ft/lbs Vibration damper to crackshaft bolt 110-130 ft/lbs Wheel lug nuts 85-105 ft/lbs
17helpful
Torque settings for 351 cleveland
Fastener Type
Torque Spec.
Main cap bots 95-105 ft.-lbs. Connecting rod bolts 40-45 ft.-lbs
45-50 ft.-lbs
for Boss 351C Cylinder head bolts (follow factory torque sequence) 105 ft.-lbs.
125 ft.-lbs for
Boss 351C Rocker arms (non-adjustable) 18-22 ft.-lbs. 5/16" Intake manifold bolts 21-25 ft.-lbs. 3/8" Intake manifold bolts 28-33 ft.-lbs. Oil pump bolt 25 ft.-lbs. Cam bolts 40-45 ft.-lbs. Cam thrust plate bolts 9-12 ft.-lbs. Harmonic damper bolt 70-90 ft.-lbs. Flywheel/ flexplate bolts 75-85 ft.-lbs. Pressure plate bolts 35 ft.-lbs. Front cover bolts 12-18 ft.-lbsI hope this helps you and please rate this
Top Maytag Washing Machines Experts
Robert
Steve
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
