I have a 900 watt punch that wont keep any fuse i put in it and need help badd! Its not my wirering cuz i have another amp in there now but its nothing even close to my baby!
there has to be sumthn hooked up wrong bc i have had same problem with my 12' subs but it was simply a matter of my rca jacks but sense you have checked them try rewiring the speakers if that does not work then your rca module may be burned out within the amp..iso then check the amp by taking the cover off and making sure nuthn is burned on the inside.or if any wires are loose or touching.
the wires you are using may not be rated for 12 volts and a certain amount of amps try using beefier wires meant for 12 volt or above electrical sources.
2x12 in sub each duel voice coil can iether wire to 1 or 4 ohms. im guessing you have everything wired up in series (1 ohm) and aer probably burning out the amp.
