Heres what you need to look for when you turn the motor on it it sucks air downward you have it going backwards. Reverse the two leads that are connected by plastic coated leads most of the wires are purple and yellow. The fan should blow upwards it probably going to be clockwise but now you know what to look for. If this helps please rate me and do a testimonial.
Hello Amy Taylor - If both the drive motor and speed control board has been replaced, then I strongly suggest contacting a professional to move forward accurately. The washer could be experiencing a wiring failure or communication error with the board, which would need further diagnosing.
Identify the blown bulb. Note that if a headlight bulb has blown, the dip beam is on the outside and the high beam is on the inside. Turn off the ignition switch and light switches.
Open the hood and replace any blown headlight bulbs. Press the plastic spring clips and remove the bulb holder from the assembly. Pull the bulb out of the bulb holder and replace it with a new bulb. It only fits one way. Be sure not to touch the bulb's glass. Replace any parking lights at the same time, they are in the headlamp unit too.
