KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
Posted on Jun 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY kitchen Aide mixer was running alittle rough /loud and now has stop completely. It is approx 24 years old and has never had any problems. It is hard to find a local repair [place. any suggestions
Anonymous
Level 2:
Novelist:
  • Expert 153 Answers
  • Posted on Jul 04, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
153
Questions
0
Helped
71204
Points
327
Two things you can do for a 24-year old machine:
1. Replace both motor brushes (Black large plastic Caps on each side
of the Moto Housing). Without these, the motor wouldn't even run.
2. Replace the Worm Gear (the cause of the Rough Loud noises)
Download a copy of the Repair Part List from Kitchenaid.com for
your model KSM90.
Also don't forget to tighten all the screws inside the mixers and use
fresh Kitchenaid Grade Food Grease for all the gears.
Burning smell when running
Your best option is to replace a 25 year old appliance. the cost to repair will far exceed the monetary value of mixer.
Mar 04, 2019 • Food Mixers
The push in button attachment on is stuck on my kitchen aide mixer
Best you let folks know the model, there is no push in button on the models most of us are familiar with.
Sep 10, 2017 • Food Mixers
Why is my kitchen aid mixers so Loud?
Could be,among other things:
Very worn brushes (although, in this case, the mixer usually stops entirely).
Worn gear(s).
Grease congealed and not lubricating correctly.
In any case, see the Service Manual at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
My 30 yr old kitchen aide runs for about 30 seconds, then shorts out- knocking the circuit out,, any suggestions?
You likely have a wire with the insulation warn off. It must be re-wired or replaced. You will be best off replacing it. Also, please stop using your unit, you may get a shock if this is happening. 30 years is a good life time, you got you money's worth.
Our Sunbeam Mixer (stand variety) is about 25+ years old and has many miles on it. . About a week ago, while mixing a light concoction it slowed down and then stopped. It started a couple days later...
You will need to search for a repair shop. There are replaceable parts in the speed control assembly that will cause your symptoms when they fail. The question is - can those replaceable parts still be obtained after 25+ years?
West Bend Model 41125 Suddenly Stopped under load
If the mixer does not work under load, then check motor , bearing , and control board.
If the mixer is less than one year old call manufacturer at the number listed on the owners manual.
To get parts for your mixer you can contact West Bend Appliance Parts - Bettervac 1-800-675-9491
3answers
Kitchen aide mixer
was the bowl snapped in to place.....push down on the back lip of the bowel until you hear it snap
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
