Question about BOSS AUDIO SYSTEMS BV9450 Car DVD Player
I have A BOSS BV9450 system and it will not hold a fm station. It will play for a few minutes then it starts searching for new station?
Posted by langley786 on
Homer Napter
    New Friend:
  • 66 Answers
Set the tuning scan settings from auto to manual... ty
Posted on Jun 21, 2011
I'm looking for the manual for a SoundLogic XT AWS-12/2970R Bluetooth splash proof speaker with FM radio. Specifically, I need the instructions for programming stations into the FM radio receiver.
I didn't see a manual online in searches.
It might be able to discover something from questions on the web sites sellling it, or ask your specific question and see if it is answered.
Example:
https://www.homedepot.com/p/SoundLogic-Bluetooth-Shower-Speaker-with-FM-Radio-and-Carabiner-in-Red-AWS-12-2970R/206079715
Quoted from llink above:
How to use FM Radio in this device This question is from Bluetooth Shower Speaker with FM Radio and Carabiner in Black
November 28, 2015
How do I use the FM Radio in this device. The device description says FM Radio but there is no mention of how to use it.
Answer this Question Answers (5)
December 29, 2015
If you push the middle button it will switch from Bluetooth mode to radio. The first time I used mine it immediately searched through all the radio stations it could detect and store that information. Kind of like when you plug in a new TV. Once that scan is done it will play the lowest numbered station, you then use the buttons on the left or right to advance to the station you want. Don't press middle button again or it will go to Bluetooth. Good Luck
December 5, 2015
Turn on the device with the power button and then press and hold the "play/pause" button down until you hear the radio. Press and hold the back and forward button to control the volume and press the back and forward button with a quick release to switch the radio channels.
December 28, 2016
Hold down the play/pause button until the radio turns on. First time you use it, it takes a couple of minutes to program the channels then use arrows keys to go through the programmed channels.
Mar 23, 2018 | The Audio Players & Recorders
My radio has recently started to go into seek mode on it's own and I can't stop it when it starts.
New HD Radio Applications Seek to Fix System Flaws ...
diymedia.net/new-hd-radio-applications-seek-to-fix-system.../7560
Jun 22, 2015 - ... Asia, and elsewhere: instead of every station having its owntransmission ... Nautel is bringing the same concept to FM-HD as part of its "HD ... Ismy radio broken? ... Inovonics expects to go into full-production mode on the Justin 808 in ... As it has been for the entirety of HD Radio's history, I guess it'll be ...
Troubleshoot problems with radio stations in Windows ...
windows.microsoft.com/.../troubleshoot-problems-wi...
Microsoft WindowsLearn about solving problems with trying to play FM radio stations in Windows Media Center. ... Why doesn't my FM radio play? FM radio may not play for one of ...
Feb 08, 2016 | Cars & Trucks
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
Set clock on 2004 Rendezvous
push and hold the H button four the hours to change and push and hold the M button to change the minutes. You just have to hold them in until the numbers change.
Mar 09, 2014 | 2004 Buick Rendezvous
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
I have a small new Philips Music system which plays CD as well as FM. It is brought from Poland with a guarantee last month. The problem is that CD'S get stuck after about 25 minutes of playing. ...
Did you get a small piece of single wire with the system. That's the FM antenna. Connect that at the back of the music system labeled FM Ant: and it should solve your problem. Just check in the auto tune mode does the radio stop at the station number correctly and if the stereo indicator light up.
When the player gets stuck, if you put another CD will it play the new CD play for 25 minutes ?. If so try playing the last track of a CD after a cold start. It it does not play the last track on a cold start , you have some physical blockage/damage on the lens rail after half position.
Mar 07, 2011 | Philips Audio Players & Recorders
Cannot play ipod in 99 daewoo lanos
instead of pressing the left/right scanning buttons hold them and then let go when you want to stop
Aug 15, 2009 | Daewoo Lanos 1999 Car Radio/stereo...
How to manual tune the radio to a station and not use the scan
i have the exact same problem. i bought a fm transmitter, so i need to tune to a unused fm station in my region wich i cant do because the audi concert tunes up automatic and skips the unused stations ... HELP !
Nov 23, 2008 | 1997 Audi A4
FM-stations
I figured it out!! YAY!!!!
so here is how you set the presets:
- click source until you are on the FM radio
- click down or the play/pause button... this shows the presets
- pick which present you want to set your station on by going right or left
- press and hold down or play/pause button until preset number starts flashing
- once flashing, use right and left arrows to select your station (if you wait too long it will stop flashing and you will have to start again)
- once you have gotten to your station, push down or the play/pause button one more time, and it should be set!!
hope this helps, good luck!!
christy*
Aug 02, 2008 | JVC RA-P11 Portable Audio System - Made...
BOSS AUDIO SYSTEMS BV9450 Car DVD Player Logo
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ray gallant
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
