Fuji FinePix A607 Digital Camera Logo
Posted on Jun 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i open the shutter I only see "noisy" coloured horizontal lines moving across the LCD. I dont see the scene I am aiming at. camera still flashes, but no picture is taken.
Juan Calca?o
Level 2:
New Friend:
  • Expert 164 Answers
  • Posted on Jun 21, 2011
Juan Calca?o
Expert
Level 2:
New Friend:
Answers
164
Questions
0
Helped
26815
Points
482
That's a major issue, seems like the sensor is dammaged, or disconected. Take it to a repair center.
Image has lines and pink in colour
This maybe two problems, the pink color hue in the picture and lines from lens shutter problems. Your LCD is still good. You have to replace motherboard and lens.
Lcd screen does not show scene and photos are all black. can anyone help?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
1helpful
I need an instruction manual for a Canon sure shot a1 panorama date camera
Ordinarily the panorama feature is utilized like this: you choose a panorama subject, and move your camera on a straight horizontal line with keeping your shutter down, and trying to capture the whole scenes into the lens. You can also stitch several common photos into one panorama picture(in vertical, horizontal, tile, 360 degree, 3d) with some programs like ArcSoft Panorama Maker.
Horizontal lines on lcd after taking photo
Sticking shutter. It will require either cleaning or replacing.
lines on photo's are due to the shutter sticking.
the video function does not use the shutter so is un affected.
1helpful
Photos taken on zoom have white horizontal lines across them. Photos taken at normal zoom are OK.
Hi!
It sounds like that the shutter cable inside lens is partially broken. It moves with the lens while it zooms, so it could loose contact while stretched - when you have zoomed the lens. Z750 and Z850 have this problem with shutter cable - it breaks. The white horizontal lines are because shutter doesn't work. I'm afraid the cable will brake soon and pictures will be too bright with white horizontal lines even at normal zoom. It is considered a hard repair - the shutter part or whole lens unit has to be changed. You can contact your local Casio service center and ask the price, but it will probably be very high. I work in a Casio service center and new lens for this camera costs about 250$. It's not a good idea to put on used lens or shutter, as it will brake again sometime - it's just a matter of time. I suggest you get another camera.
Hope this helps!
Tom
1helpful
Image on LCD jumps
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
7helpful
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
1helpful
Horizontal LINES
If you are getting fine horizontal lines thet means the picture is over exposing. most probably the apparture or the shutter blade mechanism is not working fine. needs repairs.
1helpful
2answers
Very Bright Outdoor Photos with lines
The shutter is stuck. The electronic "noise" created by the solenoid trying to move the shutter blades causes the lines on your pictures. The bright outdoor pictures is due to the fact that the shutter is jammed open. You can try tapping the camera on the sides and bottom. This may jar the baldes loose. Failing that, you will have to find a shop that can obtain a replacement lens assembly for your camera.
Vertical lines and purple artifacts when the camera is aimed at bright subjects
Current LCD display technology can reproduce about 300 different levels of brightness. Brightly lit scenes or light sources may exceed this brightness range, causing a temporary disruption (artifacts) in the live display. Artifacts are part of the display, but they are not part of your recorded image. If you take a picture while you see artifacts on the screen and then display the picture on the LCD, you will no longer see the artifacts.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
