1. Launch ShowBiz.
2. Under the Help menu select Online Product Registration. Your web browser will launch and display the registration form.
3.
You can find your serial number in the Serial Number field of the
registration form. Or you can fill out the registration form and submit
it. You will need to be connected to the internet to submit the form
online.
Can someone leave the help email address because i've tried to find it but can't. I've paid for two keys and neither will work. When you use 'Contact us' it goes nowhere that helps me.One of the worst companies to deal with. Looks as if i'll have to buy different programme, i'm not using them again. :*(
System Recovery (sometimes referred to as Factory Restore) will set your system
back to when you first purchased it. It Deletes Everything. Most
times the System Recovery does not work unless there is a recovery partition on
your hard drive created by the manufacturer. If you are trying to recover
from a set of cd's most times it does not work.
Instead of doing a System Recovery it's much easier to just Reinstall
Windows. Look on your computer for the Certificate of Authentication
(COA) Sticker. It will tell you what operating system is on your computer
and it will give you the Product Key Code (a series of 5 letters and numbers)
that you will need to activate windows. If you don't have an operating
system disk, borrow one from a neighbor, friend, relative or co-worker. Just
make sure it is the same as your COA Sticker's operating system or it will
never activate. Also make sure you get the COA Product Key Code for the
disk you borrow because sometimes the system will ask for the one that is on
your system and sometimes it will ask for the one from the installation disk.
