Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jun 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool duet washer, door locked light on door open no other lights on unable to set control
Sudeep Chatterjee
Level 3:
  • Master 3,267 Answers
  • Posted on Jun 21, 2011
Sudeep Chatterjee
Master
Level 3:
Answers
3267
Questions
10
Helped
1159304
Points
10260
The control can be locked to keep the buttons from activating during external cleaning or to help from small children starting the machine.
To activate or deactivate press and hold the "end of cycle signal" button for 3 seconds.
Testimonial: "thanks, written under signal button to do that but did any of us read that NO! You just saved me $65. service call more importantly hours of my time"
  • Joe C
    Joe C Mar 10, 2016
    I replaced the door switch and still had th problem of the "door locked" light on. THEN I come and read this and voil?, problem solved. I was ready to call for service so you probably saved me around $160-180 per the technician. Now I just wonder if the old switch is still good.
2answers
Asked yesterday duet whirlpool washer no serial number red lock light is on disconnected plug and breaker pressed the start button for 3 sec after connecting it again still doesn't work please help
Hi Bruce.
i found this on the net.
The lid can become locked if something is clogging the pump or filter drain. This means the washer is unable to drain properly, thus it won't unlock the door. It may also mean you need to replace a faulty drain pump.
Or try this link out.
https://howtofixit.net/whirlpool-washer-door-locked-light-flashing-how-to-troubleshoot-it/#:~:text=The%20lid%20can%20become%20locked,replace%20a%20faulty%20drain%20pump.
or this link.
https://www.google.com/search?client=avast-a-1&q=duet+whirlpool+washer+red+lock+light+is+on&oq=duet+whirlpool+washer+red+lock+light+is+on&aqs=avast..69i57.16197j0j4&ie=UTF-8
Control lock light
control lock light ? have you got any blockages or dirty filters you may have to clean them.
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
My whirlpool duet 2004 front load washers door is locked, time is flashing and pump is on. Unable to stop or open door. tried to unplug. Control lock is not on. My wife tried to add clothes when the add a...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
2answers
My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
21helpful
Duet HT GHW9300PW4 - The control lock is on
Hold down "end of cycle" button for 3 seconds.
chrisxx
1helpful
2answers
Whirlpool washer duet TH
Your problem could be the control board or control panel. Most of the cases it is the control panel. I replaced the entire panel and it works like new. If you can determine what the problem is, you can save yourself a lot of money by doing the repair yourself. Either one is quite easy to replace. Good luck.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
