Question about Proview PL713S 17" Flat Panel LCD Monitor
Running a proview model 700p with a hp computer, When I set the screen saver to come on ,five miniutes after leavingmachine, and sleep mode ten minutes later,,when I come back and move mouse screen lights up and almost instantly goes black and then lights up again and I get a message saying>>>my display drive stpped operating but has recovered...then it seems ok Please advise,,,I am a senior so lets not get to techinical
Posted by larki40 on
5 Related Answers
Anonymous
  • 116 Answers
SOURCE: green led light flashing on 700p proview flat panel and no picture
You need to replace the power supply! I work with these all of the time, the most common problem with thes montiors is the Power supplies do no generate enough charge to power it up to display an image! If the Power supply does not work I would look into getting a new monitor because then it is truly involved! Bad inverter, or blown LCD. I speculate that if your not getting any video after trying the new cord. replace the monitor! Sorry!
Posted on Nov 26, 2007
Anonymous
  • 6 Answers
SOURCE: Proview 700P power problem
Probably a bad inverter board.
Posted on Feb 10, 2008
Anonymous
  • 2351 Answers
SOURCE: Need help: ProView 700P Silver LCD Monitor
Your ProView 700P Silver LCD Monitor does not need a driver. Windows see's it as a plug & play monitor. Suggest you have the monitor repaired or refurbished by a pro.
Posted on Feb 26, 2008
jeremyboden
  • 16 Answers
I have a similar problem.
Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
Posted on Feb 10, 2009
noobcybort
Daniel Augo
  • 199 Answers
SOURCE: my proview 700p has lines and picture jumps can
hi,
Your TFT screeen cable has been damaged now voltage going to the Lcd circute is not correct pls swap cables i mean get it changed .
Thats why there lines on the screeen and picture is not stable .
Good luck
Posted on Nov 24, 2009
Dell Inspiron 530s Desktop fan motor keeps running
It\'s NOT the fan. Check the power save settings on the computer ITSELF. Check your BIOS settings as well. Inspirons ALL do the same thing with waking up.
Nov 05, 2013 | Dell Inspiron 530s Desktop Computer
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
Dec 20, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
Black screen
If the screen is breaking up into multiple screens, the video resolution isn't set correctly. Change the video properties back to the native resolution.
Right-click on an empty area of your desktop screen. Click on Properties at the bottom. Now click on the Settings tab.
The Screen Resolution slider should be all the way to the right, close to -> More.
The Colors should be set to the highest setting.
When you close the lid, you may have your laptop set to Sleep Mode, check that. You may also have your screen saver set to Blank, and no screen saver has been chosen.
(1.Screen Saver: Right-click on empty area of desktop>Properties>Screen Saver.
2.Sleep Mode: Start>Control Panel>Performance and Maintenance>Power Options>Power Buttons>When I press the sleep button on my computer>Then choose what you want it to do)
If none of this helps, I suggest you have a problem that HP needs to repair. Since you bought this dv9700t last July, would I be correct in assuming it's still under warranty?
Jun 02, 2009 | HP Pavilion dv9700t Notebook PC
MY LG F1 WONT GET OUT OF SLEEP MODE WHAT DO I DO?
If your laptop won't respond to the wake up keypress you can hold the power button down for five seconds and your laptop will shut down. Then you can reboot it. You might want to go to the screen saver power options and prevent it from going to sleep if the problem persists.
May 05, 2009 | HP Pavilion F1703 17" LCD Monitor
How to use this Proview LCD Monitor 17" 700P AS A TV Screen
No. The newer LCDs can do both. But they are a TV to start with the option to hook up a Desktop.
Feb 08, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
ENERGY SAver is stuck on
I know it's an older post, but you still may be waiting an answer:
What is probably happening is Your power board is failing to maintain power enough to run the bulbs and the rest.
That is why it takes long to start up and why it goes into sleep mode.
Does the power button stay lit (getting signal) or turn to amber (sleep mode) or does it flash.
powerseller
bammbammfran
Sep 04, 2008 | Proview PL926WBi 19" LCD Monitor
Dead Proview 700p monitor
my monitor samston 17`` have a problem with screen ten minute after on it`s become on / off screen ( it`s black, it`s white ) when it`s happen the wording can read, when it`s on.
Jun 25, 2008 | Computers & Internet
Proview PL713S 17" Flat Panel LCD Monitor Logo
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
