Question about TDK MP100 Professional Headphones
Our granddaughter tripped on the TDK MP 100 headphones wire. Now we hear nothing. What would you do? Thanks. Stella
Grubhead
  • 5,700 Answers
Take a look at my tip on headphones, just click my user name to find it.
Posted on Jun 27, 2011
My TDK st100 Head phones have no Sound in the left headphone
MMMmm, bummer. The earphone CABLES look rather small and vulnerable?
IF you move the CABLE NEAR the connecter do you hear any sound? How about up at the earphones themselves? If you wiggle the cable are there any sounds?
There HAS to be a 'open circuit' somewhere? Maybe the volume was set too high and the LEFT earphone happened to blow out?
And perhaps it's time to treat yourself to a NEW headset with a MUCH better and substantial connecting cable?
Anthony
Apr 17, 2018 | TDK Audio Players & Recorders
Canon mp237 error 5011
replace scanner unit. 100% works.
Jan 15, 2013 | Canon PIXMA MP240 All-In-One InkJet...
Left headphone no sound
Spray a little CRC in around the control an wiggle the control back and forth. It worked for me. Good Luck
Nov 12, 2012 | TDK Audio Players & Recorders
Headphones drop out
Cord is probably broken internally. If you are not good with wires and soldering and it is out of warranty, find someone who is or buy new headphones. You can manipulate the wire until it works and tape it in that position for a temp fix, otherwise the cord is shot.
Aug 25, 2012 | TDK 61821 NOISE-CANCELING HEADPHONES NC150
Can you hear through the headphone jack when recording and playing
YOU SHOULD BE ABLE TO HEAR PLAYBACK SIDE NOT RECORD SIDE UNTIL RECORDING IS FINISHED
Nov 03, 2009 | TDK DA-3826 2-Disc CD Recorder
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Aug 19, 2009 | TDK Audio Players & Recorders
No sound coming out of the left speaker
It sounds like you have a break in your cord right where it joins the plug. You will either have to replace the plug or buy new headphones.
May 18, 2009 | Audio Players & Recorders
Tdk mp100 headphone jack
Each of the rubber covered cords running to each ear piece has two fine strand wire bundles inside. The right ear piece has a red colored strand and a copper colored strand. The left ear piece has a green colored strand and a copper colored strand. The wires are coated with an insulation lacquer. The lacquer burns off when you heat the wire for soldering.
Repair item: 3.5 mm stereo headphone jack, shrink tubing
Plan for strain relief:. These headphone wires can't take any tension at all. You need to crimp the black cords to the headphone jack somehow.
Slide strain relief and headphone jack housing over the over the rubber covered headphone cord.
  • You need to plan a way to relieve the pulling stress on the solder joints where the two headphone cords enter your replacement headphone jack.
  • Try shrink tubing if you have it.
  • If you have some thermal shrink tubing, slide a piece over the headphone cord end before stripping the wires.
  • Slide the headphone jack casing over the headphone cord also.
Strip each headphone cord 5/8" using the 18 gage setting of your wire stripper..
Hold each headphone cord in a "third hand" soldering assist tool and tease the green, red and copper bundles apart..I wore a 10x Magnavisor and I used a sewing needle and a bright light.
Twist the copper colored strands from both headphone cords together. They are the common ground wires. The copper colored bundle will attach to the headphone jack ground.
Apply a dab of solder to the end of each of the three bundles of wire. You will see and smell the insulating lacquer as it burns off. Keep most of the wire bundle cool.
Position the two strand headphone cord and the 3.5 mm headphone jack in the third hand soldering stand.
  • Plan where you can crimp the headphone cord. Crimp it when ready.
  • The green == left channel wire goes to the tip of the 3.5mm jack.
  • The red==right channel wire goes to the middle of the 3.5 mm jack
  • The copper colored wires go to the ground of the jack..
  • Measure resistance, 31 ohms per earpiece.
  • Screw the jack cover on and finish the strain relief craftsmanship.
Nov 28, 2008 | TDK MP100 Professional Headphones
Olympus m:robe MR-100
having the same problem because i losted my headphone and my mr-100 does not work, how can i use it with the other headphones
Nov 06, 2007 | Olympus m:robe MR-100 Digital Media Player
TDK MP100 Professional Headphones Logo
93 people viewed this question
Top TDK Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Tom Chichester
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
