Question about Redhead Optics
The two sides do not line up. Thus when you look through them you see double
Posted by dpeterson132 on
How to print double sided on an epsom 580 printer
From what I can see, this printer does not have a duplexer tray. Thus, you must manually print two-sided. To do this you need a print spooler than will support this by printing the even pages, then after you flip the pages and reinsert them, print the odd pages. This works well unless there is a double-feed, because then all pages after that are out of sequence. It is best, when manually printing two-sided copies, to do them in small batches to avoid waste id your printer is prone to skips and double-feeds.
Aug 24, 2014 | Office Equipment & Supplies
Is the dryer line in side the compresser
double posted, and not double answered, back up one post (yours)
and read.
do not double post,only add to one post. one topic, PLEASE.
Jul 06, 2014 | 1998 Chevrolet Malibu
Fuel line into engine leaking
I would def think it was the wrong size. I would double check that there was not an o ring that was supposed to be in the clip as well. Thus could lead to your leak. I hope that helps wish you the best
Jan 05, 2012 | 1994 Buick LeSabre
How do I change line spacing from double to single spacing? Whenever I commence to write a letter the second line is at double spacing as are all succeeding lines. How do I get it to single spaced lines?
Open a NEW, CLEAN document. Alter all the paragraph setting until you get them exactly as you want them.
Now the tricky part.
Save the document as a TEMPLATE and save to a folder you are familiar with. Give it a good name and below that on the dialog box, choose TEMPLATE (file type dotx)
Next time you need to type a letter with single spacing, open that template. When you go to save it, Word will prompt you for a file name as a docx, thus preserving your template for another day.
Feb 22, 2011 | Microsoft Office Word 2007 Home and...
If I double a crock pot recipe (4lb. pork loin instead of 2 lb.), do I double the cooking time?
Somehow this problem ended up under Vacuums!
However- I will pass along what my wife says: "Almost 2 times as long"
Same with Turkey in the oven-- She takes the weight, and multiply's the pounds by 20 minutes on the Turkey-- Thus twice as much weight takes twice as long..
I hope this helps-
If not-- try 'Kitchen' or something closer-- or try going on line?-- maybe compare 2 different sized crock pot recipe's of the same or similar meat?
Mack B
Jan 27, 2011 | Vacuums
Hotpoint uy46 style line stainless steel, 2 year old, main oven fan takes 20 to 25 mins to start then runs too slow and some times stops, but the heat element is glowing red and very hot
The symptoms you describe are an indication that the fan motor is in imminent danger of breaking down altogether.
You need to replace it as soon as possibe, otherwise you will end up with the element burning itself out, thus doubling the cost of repair.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Hotpoint UY46 Style Line Stainless Steel...
Printer is printing double
Define "double".
Do you mean "bold" fonts, rather than "regular" fonts?
Do you mean not "advancing" the paper, line-by-line, and "overprinting"?
Do you mean "double-sided", rather than "single-sided" ?
Nov 29, 2009 | HP PSC 1510 All-In-One InkJet Printer
How to replace line on the double sided spool for my grasshog
HOW TO REPLACE LINE, PLS CAN YOU SHOW ME FROM THE PICTURES.
Oct 14, 2009 | Black & Decker 14" Grass Hog Xp...
Off line message.
could you check your settings please.
start, control panel, Printers, right click your printer, check it's online here,
or, double click your printer, when grey box appears, go to documents tab, check it's set as your default printer,
Cancel any jobs,
try to print now
or reboot and try printing again.
Hope this helps
Regards
Richard.
Apr 21, 2009 | HP Deskjet 5940 Photo InkJet Printer
Timing marks and procedures
If it is the 2.5 EJ25 motor the marks ar on the cover and pulleys. Top pulleys are Single line straight up and double straight down which should line up with bottom pulleys double marks. This should line up the single lines on bottom pulleys with 90 degree mark on outer cover both sides.The center pulley for crank should be straight up with notch in block.
Jul 23, 2008 | 1998 Subaru Legacy
Optics Logo
44 people viewed this question
Top Redhead Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Redhead Optic Expert? Answer questions, earn points and help others
