No offense intended but you need to step away and read the instruction manual step-by-step. One point I can make: The three hours you're seeing in the display when you first plug the unit in are simply telling you how long the default white bread mode is going to take to complete. It's merely a counter that counts down so at any time you glance over at the machine you'll know how much longer it's going to be before the bread is finished. The digital display has NOTHING to do with the delay timer until you start pressing delay timer arrows.
Hope this helps!
Rating our advice will let us know if we are doing you any good. Please take a moment to rate this advice. Thank you. And for all your U.S. and Canadian breadmaker needs visithttp://www.bread-maker.net/sitemap.htm
Hi Jessica Yacopino - Generally speaking, Frigidaire air conditioners timer option typically have the same procedure. The unit must be in the ON position for the timer delay stop option. For delay start, the unit must be in the OFF position. First, press time button. Then to adjust timer setting, tap or hold the UP arrow or the DOWN arrow to change delay timer at .5 hour increments, up to 10 hours, then by 1 hour increments up to 24 hours. The control will count down the time remaining until start (8, 7.5, 7, etc.). The Delay Start mode automatically selects cooling with maximum Fan Speed. The temperature maintained will be the same as previously set. To change the set temperature, press "COOL" then Up or Down arrows until the desired temperature is indicated on the display. After 5 seconds, the control will automatically change the display back to the hours remaining until the unit will start/stop. PRESSING the unit On/Off button at any time will cancel the Delay Start/Stop function. The Delay Start/Stop Feature will work until the unit either starts or stops. Once that happens the above steps have to be repeated again.
