Vacuums Logo
Posted on Jun 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm just looking for a owners manual for a Whirlpool Dehumidifier model AD50USL3 to see if there is anyway to connect a hose to run to a drain instead of having to empty the water collection chamber.
xalint1
Level 2:
Sergeant:
  • Expert 152 Answers
  • Posted on Jun 20, 2011
xalint1
Expert
Level 2:
Sergeant:
Answers
152
Questions
0
Helped
82191
Points
525
If your looking at the front panel of the unit look on the left side of the bucket there is a cover for the optional hose attachment.
Whirlpool owners manual
it seems from the ones that I have worked on it should just twist or there will be a buton if it is twist you simply twist it until you hear it pop and it should pull out
Goldstar dehumidifier Model DH404EY7 Manual needed
Here is a direct link to the User's Manual for that device:
http://www.appliancefactoryparts.com/content/pdfs/122424-8.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck and take care.
Joe.
Sep 14, 2011 • Vacuums
I'm looking for the user manual for the delonghi de500 dehumidifier...
First of all, here is a direct link to the ONLINE USER'S MANUAL for that model:
http://dl.owneriq.net/8/88e23cb9-80fb-4340-b43e-60b13037ea08.pdf
Joe.
1helpful
Hi, I have the Dehumidifey in the boat and have connected a pipe to the back so it draind continually out . The problem is that it still fills up the container and doesnt drain out the pipe. I cannot find...
Pipe or hose must be totally sealed to dehumidifiers output. Then make gravity work... all pipe runs must be downhill, or else it will back up and come out the dehumidifier.
Jun 18, 2011 • Vacuums
How to connect hose and wand?I don't see any place to connect hose?
Here's a download for PDF file that is the owners manual. Check page 8.
http://www.dirtdevil.com/manuals/?id=83831cab-2807-439b-811d-52aab2fd84ee
Our Gen3 Kirby still works but is extremely loud not - I am currently only using with the wood floor attachment (no brush) - thoughts?
this could be the impeller fan next to the motor shaft under your attachment hose connection.
to determine this, remove the hose from the unit, and turn the fan shaft with your hand looking down inside the unit. You should see blades on the impeller fan, and they should all look squared off and curved. If any of them are broken or worn, it will make the unit louder than normal.
Also, the hose attchment has an increased noise more than using the brush attchment anyway because it increases the suction for the hose more than on the carpet. IE the motor runs faster giving you more suction.
An Impeller fan for the G3 Kirby will run about 18-39$ for the fan. More for labour.
Good luck,
Mark
I have a GE dehumidifier that i hooked a garden hose to for direct drain. it will work okay for awhile then will only drain into the drain bucket. is there something i can do to ensure that it will drain...
This seems to be a fairly frequent complaint on these GE dehumidifiers, and none of the solutions I've read here or anywhere else have fixed mine. My hose is clear, straight downhill, tight to the nipple with a good gasket, no plugs visible in the nipple, but has always filled the bucket rather than drained through the hose (and it's always bone dry). After two years of this and emptying the bucket, I'm about ready to disassemble it to see if I can fix it but with all of the other unresolved complaints I've seen GE should step up to the plate and post a solution.
Aug 19, 2010 • Vacuums
I hooked up a hose to my Whirlpool dehumidifier for continuous drain and returned the bucket like the manual states. The bucket continues to fill and shut off. Model AD25DSS1 Serial Q1123013
Hi, check to make sure the drain hole connection on the Dehumidifer's reservoir, that you have the hose hooked to, isn't plugged.
Also, you might want to see if the hose connection on the reservoir, still has the "knock out plug" still in place. Look at the hose connection on the reservoir, and if you can't see through it, or put a screwdriver through it, you need to punch it out the middle with a screwdriver. Open up the hole as much as you can so it will drain into and through your hose.
Check your hose also, as it might be plugged, disconnect it and blow through one end to make sure the water can flow through it.
Those are the only three things that could be preventing it from draining out the reservoir, through the hose connection, and through the hose to your drain
Take care
Jul 18, 2010 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
