RCA RTD155 System Logo
Question about RCA RTD155 System
I NEED A BOARD PART BY # LVP200630-001 - RCA RTD155 System
Posted by cesar_albert on
Anonymous
  • 1,116 Answers
You can find all available parts for your model at the following link:
http://www.partstore.com/Model/Thomson/RCA/RTD155.aspx
Posted on Jun 20, 2011
1helpful
Philips 42pf5331/10. How to replace 3104 303 50161 psu with 3501q00203b. (Mpf7435) . Cannot see connection to logic board
You will need the correct board, if one isn't available the TV will need to be recycled. Unfortunately, it's quite common for one model to have several non-interchangeable boards
Do i need a power board or main board
Let me be sure I understand this, you have 2.7 vdc when the connector is going to the main and nothing when it's unhooked? or is it the other way around?
Lg TV power board led blinks five times ?
I thinks you need use a new power board instead of the old power board ,you can have a look https://www.abctay.com ,you may find what you need.
I need to reset my power board on my Fujitsu 50" plasmavision
Just being curious from what little information that you provided, why would you reset a power board? The power board has a fuse to replace when the supply goes out, however if it has gone out, then the board is in need of repair. Typically it is from the capacitors going bad on the board and need replacing. Qualified service tech only...
1helpful
Need a signal board for kp53hs30 dont know the no. lost the board.need acomplete board to buy
you need every number on that tv,including numbers off the board,if you dont have it,junk the tv
1helpful
My HDMI inputs dont work on my VIZIO gv47L FHDTV10A what board do i need to replace
Most likely you will need to replace the main board. That model # uses several different main boards. The part # will be listed on the board. Make sure you order the exact part # of your old board.
http://www.shopjimmy.com/vizio-3647-0012-0150-main-board-for-gv47lfhdtv10a.htm
I need to purchase a main board for a Proview, MDL # HV205 LC TV.
Tries Websites Shopjimmy.com,Ebay.com should have this reburbish Main Tuner board.
PDP5016H Akai Plasma TV
is the control board the one with the rca jacks on it,for sound and video input?if so email me at [email protected],i need one.
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
