Question about Xerox Phaser 8400 Laser Printer
I have xerox phaser 8400 : when i turn it on it says : service needed fault 37 002 47:115353\r\ncould anyone help for that . thanks
Posted by sabry894 on
JDTec
  • Xerox Master
  • 4,338 Answers
Service Manual says:
37,020.47 = (8400) Strip Solenoid
37,020.47: Strip Solenoid disconnect.
The strip solenoid is not drawing the
expected power.
The Solenoid (relay) may be bad, or the power to it is low.
The Stripper Solenoid positions the stripper blade. The solenoid mounts on the Upper Inner Duplex guide and activates the strip solenoid lever, which in turn rotates the Stripper Carriage
until it hits the transfix ground pins. This action causes the stripper blade to drop onto the deadband of the Drum.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jun 20, 2011
I have a xerox phaser 8400 printer that will not do anything, just reads "fault 37,004.40:32046" what can I do? Thank-you
The 37,004.40 error means that the ink reservoir is not heating up correctly. Make sure the printer is plugged in directly into the wall and not on a power strip and cycle the power to the machine (turn it off and back on). If the problem continues, you probably have a bad printhead which you have to replace. For the 8400 the part number is 650-4303-00. Iteminc.com has that part in stock and ships same day. Here is a video that shows you how to replace the printhead. Hope this helps and thanks for using FixYa.
Aug 16, 2011 | Xerox Phaser 8400 Laser Printer
What is the Xerox Phaser 8400 printer error code 07.010.43:43923? Much appreciated. Thank you.
Try this:
The printer has encountered an error state without the benefit of a code. Turn the printer off for 30 seconds, then power back on.
If the Printer Error message returns, press the i button on the printer's front panel. The actual error or fault number should be displayed. Note the error or message and search the knowledge base for the error.
Also:
Based on the problem description provided, we have determined that your printer needs service.
Please turn your printer off and use one of the methods below to make arrangements for service:
If using the local service provider website, please perform the following steps:
  1. Enter your zip code in the space provided.
  2. Choose a mileage distance. The search will locate a Service Provider within the specified range if available.
  3. Click Go. The web site will return a list of Authorized Service Providers (ASP) with their company name, address, phone number, and fax number.
Feb 12, 2011 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Fault 37,008.44:9490
this is a Preheater error 37,008.44 I will put the link below so you can see how to fix it the repair for that error is on page 105
https://www.office.xerox.com/partners/products/Phaser8400/SQRG/8400_85XX_Service_Manual.pdf
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 23, 2009 | Xerox Phaser 8400N Thermal Printer
Service message: Fault 37,004,40:50081
Hi abonk:
This is your problem.
37,004.4x - PEST_FAULT_RESERVOIR0_HEATER_DISCONNECT
PEST - Reservoir0 Disconnect Reservoir0 is not drawing the expected power from the
supply.
1. Run the printhead Reservoir Heater test.
2. Verify printhead wiring.
Your preheater needs to be replaced.
Xerox Preheater Part # 119641980
This part will have to be replaced by a certified Xerox technician.
Hope this helps
May 22, 2009 | Xerox Phaser 8400 Laser Printer
On bootup of Phaser 8400 recieve fault 37,004.40:117545
PEST Fault 37,004.40: xxx
Printhead reservoir 0 disconnect:
Reservoir is not drawing the expected power from the power supply.
Service manaul states the the printhead needs to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 10, 2009 | Xerox Phaser 8400 Laser Printer
37,004.40:39187 with the fan running
You have a failed resivor heater in your print-head, your print-head will need to be replaced, unfortunately more expensive (800$) then buying a new Xerox Phaser 8550dn from Tiger Direct. ($750 ish)
Mar 06, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 8400/8500/8560 maintenance kit
No, it will not work because the chip (CRUM) is not compatable.
Jan 13, 2009 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 fault
I have the same problem. Xerox says they need to send someone out and can not tell me what this code means.
Prior to the error I have having light streaking on the page. Took everything apart and cleaned and it worked OK for 2 days then returned to streaks.
If anyone knows what to look for please offer assistance.
Jul 24, 2008 | Xerox Phaser 8400 Laser Printer
PHASER 8400
1, The NVRam memory is corrupted.
2, A jet heater is not working
3. the electronics module is bad.
Parts possibly bad are the NVM, the Print Head or the Electronics module.
Hard without a manual to determine, all are expensive.
May 30, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 fault 37,016,43:24800 ????
Sadly that is not good.That normally is one of the heaters in the print head has failed not warming up enough to allow the ink to remain liquid. It frequently is the result of a failure of the electronics module, none of the most likely problems is a cheap fix. I will give you the list of most probable causes.
Wish I had a more hopeful answer.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
119649580 1 *ELECTRONICS MODULE (STRIPPED)
671529180 1 I/O BOARD
650430300 1 *PRINTHEAD ASSEMBLY
The electronics module. Listed as stripped, means it comes without the ram and nvm boards. When that fails it is a portion of that module that supplies the heater voltage. I think its a 50 volt source off hand.
Apr 22, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8400 Laser Printer Logo
341 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
