I have a 93 pathfinder SE 4X4 automatic transmission that had full power, new starter and battery. Sometimes it will start and sometimes not. By passed starter relay by adding push button start and it started 6-8 times then nothing. I finally figured out that it was the neutral safety or inhibitor switch on the 4 wheel drive shifter. Just an idea..good luck
SOURCE: Test Inhibitor Switch
HELLO I HAVE A 95 NISSAN ALTIMA THAT DID THIS SAME THING AND IT WAS THE STARTER CHANGE THE STARTER AND YOUR PROBLEMS FIXED
SOURCE: 1991 Nissan 240SX starter will not turn!
If you've applied 12VDC to the solenoid and it does nothing, not even click, then the solenoid is toast!
SOURCE: When I turn the key in the ignition nothing
Do you have power inside the car. If so then the starter is bad. If you have a remote starter solenoid on the fire wall or fender change that first. You may also want to check all the wires on the starter and make sure they didn't come loose.
