Question about Razor E100 Electric Scooter
Battery charged and power light comes on. motor is not working.
Posted by loribones on
boyfox
  • 25 Answers
None
Posted on Jun 21, 2011
Dead battery, used jumpers. Lights work dashboard lights up. Motor will not turn over
If the battery is very dead, it can take a while for the dead battery to regain enough charge to start. If you are jump starting from a jump box and not a running vehicle, there may not be enough power available to get the charge to a level that can start the vehicle. Hook up the jumpers cable to a running vehicle and allow 10-20 minutes for the battery to gain some charge. Monitor both batteries carefully during this time and should any unusual amount of heat or if smoke starts to come from either battery, shut everything down and disconnect as quickly (and safely) as possible.
Nov 14, 2016 | Cars & Trucks
Why does my new motor trend power house jump starter with air compressor not take a charge from the a.c. or d.c. charger?
Contact manufacturer. If still under warranty they should replace. Sounds like the internal battery is dead...there has to be a little "juice" left in the battery for the charger to have a complete circuit to charge...some of these units take 24 or more hours on an initial charge.
Hope this helps,Ron
Nov 30, 2014 | Power Center Jumpstart 11-411
I have a 1998 Plymouth Grand Voyager SE and I just replaced Alternator, battery, PCM. The alternator is not receiving enough power to charge the battery. Only putting out 11.58. What could be the p
First, you state "the battery is only getting 11.58". This implies the alternator IS charging albeit too low. I would connect the voltmeter to the main terminal on the alternator and take a reading before starting the motor, then again with the motor running at around 1500 RPM (fast idle). This will indicate whether the alternator is working or not.
Getting back to the ign light, does it remain at the same brilliance before starting the engine and after?
Jan 20, 2014 | 1999 Chevrolet Cavalier
Engine fails to start
What makes you think the battery is charged sufficiently? My guess is that your battery doesn't have enough power to crank the engine (just because all the lights come on doesn't mean the battery is good enough to crank the engine). Try jumpstarting the car, or charging the battery. If your car starts, then your battery is getting old, it's time to replace it.
Dec 06, 2013 | 1999 Porsche 911 Carrera
Car keeps dying
Try replacing your battery as it sounds like your battery is not holding charge. When you get a boost from other car your using the other cars power to start yours. It only takes a little power to light dash lights etc but takes a LOT of power to start motor.
Nov 22, 2013 | Chevrolet Cars & Trucks
MY PLYMOUTH GRAND VOYAGER 'S HEADLIGHT'S AND DASH LIGHTS WORK, BUT THE ENGINE WON'T TURN OVER. THERE IS NO SPARK COMING FROM THE ELECTRICAL WIRES.
When you say no spark, are you talking about the spark plugs, or just the general wiring?
If the engine won't turn over, then it isn't moving, and if it isn't moving then you need to check the following in this order:
1) Does the battery have power i.e. around 12.4 volts or over?No? Charge, test or replace battery.
2) Do the car's head lights dim considerably if turned on when attempting to crank? Yes? Possible lack of battery charge or faulty battery.
3) Assuming the battery is fine, can you turn the dash warning lights on and off with the key? No? Faulty ignition switch.
4) Is there a click sound when you turn the key, but no starter motor spin? Check starter motor connections or replace starter motor.
If none of the above prove to be of help, then please report.
Oct 31, 2012 | Plymouth Cars & Trucks
Pedego hub motor jumped and then no power. Fully charged battery and have lights showing fully charged battery.
Please give us a call so we can fix the issue! (800) 646-8604
Thank you,
Pedego Team
Oct 01, 2012 | Motorcycles
I have 18volts at the box that the battery leads go to and the consol leads go out of. the warning beeper goes off even when standing still and in neutral. i have tryed bridging the leads from battery to...
18 volts is not enough voltage to run this scooter. You have 2 batteries that should each read a max voltage of 13.5 volts each or 26 to 27 volts when fully charged and measured in series. 2 batteries that are 50% charged will read 24 volts. Your batteries are almost dead by this measuring method. Charge them up or replace them and your scooter should run. Hope this helps.
Feb 18, 2011 | Electric Mobility 4 Wheel Power Electric...
PLEASE HELP!! I am going on a business trip tomorrow and ALL of my requisite files are on my Dell Latitude D610 that won't power on. PROBLEM: once I removed it from my docking station at work, it won't...
When you say you "tried turning it on with the battery removed", did you leave it plugged into the wall with the charging adapter at the time? Please clarify that you tried to use it while plugged in without the battery and it would not power up? When you plugged it in without the battery, was the green charging light on? Or did you get no power light at all?
With your battery in, try using a different outlet to plug into. Plug it into another outlet and when the green charging light comes on press and hold your power button on your keyboard and do not release it for 30 to 45 seconds. Tell me if this boots up the pc even if just for a moment?
There are three lights on your keyboard that should come on when the laptop is plugged in and turned on. One is the power light, the other is the battery charging light and the last one is the hard drive indicator that looks like a round cylinder on the picture. Tell me when you plug it into the outlet and the battery charge light is on, does the hard drive light come on and/or flicker when you try to power up the laptop? How many lights come on when you press and hold down the power button with the cord plugged into the wall?
Jan 09, 2011 | Dell Latitude D610 Notebook
Razor E100 Electric Scooter Logo
100 people viewed this question
Top Razor Toys Experts
ROB
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Razor Toy Expert? Answer questions, earn points and help others
