Dear i have nec np 4000 i have replced both lamps bt i cant reset them because it is not starting with new lamps .
do i have to press any key to reset lamps .
thank you
Without remote is not possible. Any way try press and hold the power bottom on the projector About 4 seconds while projector is in standby mode . Not sure it will work but you can make a try.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by type in " lamp hour reset" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
go to menue / reset/clear lamp hours,
all the buttons needed are on the box, push menu & with the cross navigate & with enter confirm selection, exit gets you back at any time, on the nec/support website you can get the np-v series manual
good luck
It seems that the lcd panels are failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
After replacing lamp in MT-830(NEC) press and hold "on" button for 10 seconds to reset lamp hours. If projector has beyond 2100 hours press the "off" button for 10 second.
