ML310
not one word stated by you as to what is in the box.
are you running a raid card? are there drives connected to it.
how many.?
is the card setup as raid 0 to 6 ? or what? RAID mode.
does the SSA program (free at HPE.com) show all drives healthy.?> IT must and is always first look there. always.
Ive no idea all what is inside your server. and matters big time.
how long as MS Sev, 2008 been installed.?
1 week, 1 year,
1 day, or I just now installed, 2008 server.
and last
does the HPE.com web site even show it supports 2008?
it must support it and must have driver that match it.
learn to ask at HPE.com and never at fixya, FIX is NOT HPE
not by a country mile.
ever seen real HP on topic, btw,1st google hit on topic.
https://community.hpe.com/t5/ProLiant-Servers-ML-DL-SL/ML310-G5-SATA-Raid-cannot-install-2008-R2/td-p/4549580
amazing no? HP is like real and there.
Could be memory take out clean and swap around if you have more than one or you may have to reinstall windows
SOURCE: 02A2: BMC System Event Log(SEL) Full
In HP prolliant server sets, setup also logs system events. This error is due to that log. Enter setup, trace log and clear all events.
SOURCE: server error
Clear System Event Log thru CMOS setup or the management software provided with server . The SEL is full that is the reason the error message
SOURCE: Please help, I have a
hmm probably the boot from cd is not initiate ..go to bios settings and restore optimal factory defaults..after that rearrange the boot device order to boot first from cd..after that save changes and reboot.. ....make a boot-able cd with server 2003 ...(it is enough cause it will update to the latest if it is genuine ..) and when its done insert and reboot...it will prompt you to press any key to boot from cd ..
for most of them pressing the F8 on during the boot will get you directly to the boot menu ..and selecting the device here will bypass the bios settings ..but not all supports this ..or have the same key for boot menu ..usually it is written on the screed near the key for bios..
anyway ..I will link a fully described step by step installation ...be careful cause there are steps that are not a must to choice..but in general it almost like a Xp installation ..
the thing that keeps you in this moment is the boot device order..(probably the boot from cd is disabled in the bios)so ..go there and check ..and thats all..
here is the link to have something to consult with on the run ..
http://www.petri.co.il/install_windows_2003.htm
Testimonial: "Great advise...my CD was bad. "
SOURCE: Hi I am having HP Proliant
Remove the BIOS battery and BIOS jumper and place it again. You won't get the error message again at the startup
SOURCE: hp proliant dl380 g4 not booting from hard drive
I bought an HP DL380 G4 from here, and called them up any time I had a question like this. These guys were amazingly smart. Perhaps you can call them up and pretend to be a customer?
Use password reset disk to reset HP Windows server 2008 lost password.
1. If you have created it, insert it into HP computer and type incorrect password when you are asked to input logon password.
And then click "Reset Password" link to begin Windows server 2008 password reset.
2. If you have not prepared it before, create one now with Windows Password Genius.
Insert password reset disk into locked Windows server 2008, and boot HP server from reset disk. Choose account and click "Reset Password".
http://www.isunshare.com/windows-password/two-ways-to-create-a-windows-password-reset-disk.html
If you forgot your password on Windows 2008, how will you do? Undoubtedly, most of users may turn to the administrator to reset Windows 2008 password. But what should you do if you forgot Windows 2008 administrator password? Generally speaking, it is better to find a Windows password recovery tool to solve Windows password lost problem. Here, Windows Password Unlocker Enterprise is the one which provides you an easy and safe way to reset lost Windows 2008 password. Before dealing with your password lost trobule, it is better to learn more about Windows 2008.
What is Windows 2008?
According to Wiki, Windows Server 2008 is one of Microsoft Windows' server line of Operating Systems. Officially released in February 2008, it is the successor to Windows Server 2003. Windows Server 2008 R2, a second release, was launched to manufacturing in July 2009. It expands existing technology and adds new features to enable organizations to increase the reliability and flexibility of their server infrastructures. New virtualization tools, Web resources, management enhancements, and exciting Windows 7 integration help save time, reduce costs, and provide a platform for a dynamic and efficiently managed data center.
How to reset Windows 2008 passwordï¼ÿHere, Windows Password Unlocker Enterprise allows you to use a bootable CD/DVD or USB flash drive to reset Windows 2008 admin password in 4 simple steps.(Take USB falsh drive for example)
