Question about SanDisk 4GB microSD High Capacity Memory Card
My sandisk is failing to format even to delete items which are inside it is saying disk is right protected whilst it is not protected
Posted by seanpmtaw on
Ebiau Daniel
  • 107 Answers
Connect the disk to a computer and then click right on My Computer then click Manage and then try formatting it from there. if this fails then your disk might be locked. try finding the lock on the disk its kind of a small switch button on the sides of the disk try pushing it on either sides while trying to format it. When it is locked it will say that the disk is Protected and when unlocked it will not be protected thus enabling it to format.
Posted on Jun 20, 2011
File Repair Services
  • 827 Answers
Hello Sean,
Please try to format the SD card using the SD Formatter 3.0 for SD/SDHC/SDXC. The software formats all SD memory cards, SDHC memory cards.
Download the software from the link provided below :
http://www.sdcard.org/consumers/formatter_3/
  • seanpmtaw Jun 20, 2011
    guys i was fully helpd by FIX YA expert Guru .my sd car4gig was failing to format and erase al th iterms which were inside bt when i visited this site i get th right help wich i was loking for it formated my sdcard without error thank guys 4yo assistance keep it up guys i luv it.they jus send m the download link software for sd sards which is centred on tht .thts great
    sean pityus mutawu
  • File Repair Services Jun 20, 2011
    if the solution helped you then you can vote us .
How can i unwriteprotect my 16gb sandisk flashdisk
Open up a command prompt as administrator
Type diskpart and press Enter
Type list disk, and you'll get a listing of all drives on your machine.
Type select disk # to select a disk. You can use the Size column to identify which one it is.
Type attributes disk clear readonly - change your USB's properties so that it is no longer read-only.
Feb 04, 2018 | SanDisk Computers & Internet
How do i remove write protection on a sandisk cruzer 16 gig usb device
Format it with your windows format tool then right click on it in the device control screen select "run as administrator"
Oct 07, 2014 | SanDisk Cruzer Edge Sdcz51-016G-B35 16 Gb...
My sandisk curzer Edge 8gb pendrive say write protechted how can i format it.
in "my computer" right click on your "removable disk" and select format...
if that does not work..
'Start' Right click on 'Computer'
'manage'
'disk management'
select your device (removable disk)
'format' or 'delete volume'
if 'delete volume' after ot is complete select new simple volume
success
Jun 19, 2012 | Electronics - Others
Cannot format sandisk cruzer edge pendrive, disk is write protected
https://kb.sandisk.com/app/answers/detail/a_id/2399/~/sandisk-secureaccess-3.0-support-information-and-download-page read this it may still be password locked.
Feb 01, 2018 | Computers & Internet
Hi i am unable to delete files on a sandisk micro sd 2gb. i have tried various programs to delete them. the file themselves say it is 0kb but still says full when its in my phone is says it is full. thanks
ok do you want to delete individual file or clean it completely.
if the memory card has gone corrupt the easiest solution to find out whether its gone faulty or just corrupt would be to format the memory card but this would mean losing all that is on there.
to format your card
1. insert it in your computer or laptop
2. go to my computer and you should see your memory card or it may say removable disk :? (? being a letter which it will name it)
3: right click on card and select format from the drop down menu
4: select quick format and click next
and all being well should be clean and ready to use again if it fails the format it generally shows that the memory card has gone faulty
Jan 19, 2011 | SanDisk 2GB microSD Memory Card
Dear sir i am using sansa express 1gb .its not working at all.when i switch on the player it shows "sansa" for 2 min ,then it disappears.after that i wnt be able to open it.but my computer is dtecting when...
There is online support for Sansa Express. When searching for Answers on the topic "express" it gives next list:
http://kb.sandisk.com/app/answers/list/kw/express/r_id/101834
Going to item 13 "Sansa player not recognized by the computer":
http://kb.sandisk.com/app/answers/detail/a_id/42
When the player is brand new, click on the link in the opened page in the page top or use next direct link:
http://kb.sandisk.com/app/answers/detail/a_id/42#brandnew
Else follow up the instructions as described in item 13.
Sansa Express user guide
If more help is needed just post a comment.
Sep 24, 2009 | SanDisk Sansa MP3 Player
Can't Delete
try formating the disk,
just right click on the drive in windows and format.
that should clean it up.
as it is corrupt.
Mar 15, 2008 | SanDisk Sansa e250 MP3 Player
Cant take songs off Says " Write Protection"
There is a LOCK switch on the side of the SD Card.
Slide it away from the LOCK and youll be all set.
Best of Luck.
Oct 28, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
SanDisk 4GB microSD High Capacity Memory Card Logo
541 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
ChinthakaJ
ChinthakaJ
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
