Computers & Internet Logo
Posted on Jun 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to beable to enlarge or shrink sizes of printed and picture documents
Anonymous
Level 3:
  • Master 480 Answers
  • Posted on Jun 20, 2011
Anonymous
Master
Level 3:
Answers
480
Questions
Helped
85970
Points
1473
HI, If you want to shrink or enlarge what your printing, there is always an option to go to print preview. All you need to do is to change the percentage of the preview as it also changes the size of what you are printing out.
Thank you for using Fixya.
2answers
How to enlarge print when copying on Envy 4500
To enlarge the print when copying on the HP Envy 4500, you can adjust the zoom or scaling settings in the printer software. Here are the steps to follow:
1. Load the document or photo that you want to copy onto the scanner bed.
2. On the printer control panel, press the Copy button.
3. Use the arrow buttons to navigate to the Zoom or Scaling option and press OK.
4. Use the arrow buttons to select the percentage by which you want to enlarge the print. You may be able to choose from a list of preset options (such as 125%, 150%, or 200%), or you may be able to enter a custom percentage.
5. Press OK to apply the changes and start the copy job.
If you're using the printer software on your computer to control the copy job, you may need to follow slightly different steps depending on your operating system and the version of the software you're using. However, the basic process should be similar. Look for options related to zoom, scaling, or print size, and adjust the settings as needed to achieve the desired level of enlargement.
Suddenly the font size on my printer increased greatly.How can I get it back to normal????
Printers do not understand fonts. They print dots, and they print them wherever the application that created the document, modified by the print spooler settings tells them. Thus there is nothing wrong with the printer. Check the print driver (spooler) settings. Do you have them set to "enlarge to fit page/shrink to fit page"? Do you have the wrong size paper selected? That, along with the previous problem, can cause major issues.
2answers
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
Note
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Tip
Selecting Scaled Printing changes the printable area.
Hope this helps
Mark
2helpful
How to change print size
Assuming you're referring to the print size of the fonts - letters ..... or the size of the printed page ...
If you're printing from your computer, you'll need to change the size of the font (to a larger font size) on your document before you print, or adjust the print Properties ... to fit to page, or magnify the size of a small document ...
If you're printing a pdf file, you can specify the size of the document using the enlarge (%) before you send it to the printer
How to print enlaarged photo
Click on the the little print image that has paper coming out of it on the top of it,next click preview on your computer.Next click on the "Shrink to Fit" when your page or picture comes up up stroll down to the highest number or whatever you prefer and hit Print when you are satisfied with your picture.I hope this was helpful.
2helpful
How to i make my print larger on my hp deskjet printer d1341
Are you trying to fix a problem?
OR
Do you just want bigger print?
If the print has been shrunk, check the printing preferences and look for a scaling option. It may be set to "Shrink to page" or something similar.
If you just want bigger printing, you will have to enlarge ythe document's font before you print the page. If this is the case, and you can tell me what you are printing from, (Internet Explorer, Word, Goggle Chrome?), I may be able to instruct you on how to enlarge the print.
Re: How to make a enlarged document
In some printers there is a enlarge document printing support. Like Konica Minolta heavy duty printers or copiers. They support custom paper size in printer properties and also can support a large paper form a paper roll.
You are using inkjet printer so I feel there in no limit of paper size so you can print a custom size paper what you want.
Before printing just go to the properties of the printer and add a new custom size in paper menu then put that size paper into printer hope it’ll work. You must change the paper size from the application from where you are printing that paper.
Enlarged Picture
yes it is fixable. this problem is due to more supply is going to h/output stage. please check 1 power supply for more voltage then normal. 2 component failure or settind in horz. stage to be checked. 3 print crack in h/output stage you can not control from remote control.
Grand Canyon Tech
Grand Canyon Tech
