Unplug the unit. Remove the top cover by unscrewing the 3 screws in the back and sliding the cover back and up. At the control board, disconnect all the wires from the board, remove the screws holding the panel and pop the panel off. Remove the front panel of the dryer. Down on the right bottom corner inside the dryer, look for the large round tube where there are 2 sets of wires connected around it. There are 2 high limit switches, one on top right and one on the bottom left. The high limit switch on the bottom left has the reset button in between the wires. Push it and you should hear a click. That will reset the switch. NOTE: this is only a temporary fix. The manufactures recommends replacing that switch if it should trip because it will trip again. Good luck
