Electrical plug that is broken can be fixed however it is no longer safe to use..Electrical current may leak while holding the plug that might cause electrical shock.It is better to replace it with a new one.If the plug can be remove using a screw or if it just fixed using a bolt then you can just buy a new socket or plug.That helps you lessen your expenses.Hope this helps..
