SOURCE: Paper Jam/Kyocera C850/C850D
There will be a piece of paper stuck in there follow the instructions again opening every door on the left side. If there is not some paper the likely thing is that the paper sensor is jammed open or the light reflector sensor is dirty or the last thing is one of the sensors are faulty.
But I know these machines very well and the sensors rarely go faulty so I'm 98% sure there will be just a small piece of paper stuck in there. (It may be between the two doors or stuck behind a guide.
SOURCE: Kyocera Error
Signifies comunication error between mainboard and engine.
Only hope would be check and reinstall printers firmware via flash card in side socket.
Check connections on the boards.
Replace main board.
Error is stated as for F040: the .0183044 is just page count.. no match for just 040 in service manual.
Cheers
SOURCE: Kyocera FS-1020D process unit in two pieces
best thing todo is get a new PU-102, the gap between the drum and dv unit is to large and the toner is not transfering.
SOURCE: Mac OS10 print driver for
Go to kyocera's website to download, ckick this link and it will take you to the driver you need.
OS 9
OS 10.2 and 10.3
OS 10.4 and 10.5
List of other drivers for this model printer.
