Cameras Logo
Posted on Jun 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Recently my Canon camera stopped taking pictures. It will take a picture if the flash isn't needed or of you turn the flash off; however, if the flash is needed, the orange flash light will come on but the flash light on the screen will blink and no picture is taken. Thanks for your help!
Anonymous
Level 2:
New Friend:
  • Expert 50 Answers
  • Posted on Jun 19, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
50
Questions
0
Helped
5610
Points
157
If your camera is under warranty bring it to the nearest Canon Agency to have it check and repair. Most of the time the problem is mechanical and only the qualified technician can fix it.
7helpful
My Canon powershot SD1000 screen isn't working. Iv'e charged the battery but when I turn the camera on, the screent is black. It won't take any pictures
It's very likely the CCD sensor that needs to be replaced. If you need to have it serviced, this place is excellent for the Powershots and not much at all if you need to have one fixed: www.camerasandparts.com
Before having it fixed, press the DISP button first and make sure you just didn't turn the display off. If you end up needing service for the Canon, that place above is really great for these cameras.
How do I set the resolution on my Canon SD850?
The instructions for changing the resolution are on page 30 of the manual.
If the pictures are fuzzy, increasing the resolution won't help. The most likely causes of fuzzy pictures are as follows
1) Focus. Check to make sure the focus is on the subject. If something else in the picture is sharp while others are not, then the camera may have focused on the wrong subject.
2) Subject motion. If moving objects are fuzzier than stationary objects then you need to use a faster shutter speed (or flash).
3) Camera motion. Just because the camera is on a tripod doesn't mean it doesn't move. One philosophy says that if a tripod is light enough to be carried then it's not sturdy enough. For a compact camera like the SD850 that likely isn't the problem. However, you can still shake the camera when you press the shutter release button. Try setting the self-timer. This allows time for the vibrations to die down before snapping the picture.
In your particular case, I think we can assume that the subject isn't moving, so #2 doesn't apply. To assure proper focus, make sure the painting is flat and perpendicular to the lens axis. If the painting is tilted relative to the camera, then different parts of it will be at different distances and the camera won't be able to keep all of it in focus.
Also, make sure the front of the lens is clean.
1helpful
SOMETIMES THE PICTURE ISN'T ON THE SCREEN. I TURN IT TO ONE OF THE CAMERA MODES AND NO PICTURE COMES THROUGH ON THE SCREEN. THE ONLY PLACE IT DOES IS WHEN IT SET ON C.
Hi Linda: Sometimes?
If you can check menu settigns there, isnt the LCD screenviewer, then sound like a malfunctioning CCD (Charge Coupled Device) image sensor... in both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check this link for additional details in this previous solutions for an Defective CCD and next contact your Canon service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
--cannot view anything to take a picture of--the view screen is black but I can see al menu items and can display settings. Flash works. I can see cannon signal clearly when camera is turned on. I am...
The A6XX series is prone to stuck shutter problems, particularly if the camera isn't used very often. Lens lubricating grease can coagulate on the shutter, immobilizing it. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
1helpful
I was trying to take pictures in a cave that had some light but not a lot. The flash will pop up and the light bursts, but it will not take a picture. It just keeps focusing in and out and it won't...
It's probably too dark and the flash isn't powerful enough to assist the focus mechanism on far away objects (more than 10-15 feet).
If you will need to switch to manual focus and maybe manual exposure.
When I turn the camera on the screen is black. It shows the menu display ok and it will display pictures already taken but it is not possible to take pictures as the screen is just black..
Two things there, first... could be a problem with the viewer screen, or, second choice could be a problem with the CCD sensor or go to bad; in both cases this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Canon service.
Hope this helps; check it and keep us updated..
I have a new 580EXII mounted to my Canon 7D. I do not seem to getting the "double flash" (not sure what the technical term is) that I expect and pictures are coming out dark. I'm think...
Holly, I believe you are referring to the pre flash for the ETTL function. both flashes happen so so fast that it looks like one flash. If your pictures seem dark make sure your flash is set to ETTL (press the MODE button unlit ETTL is displayed) this way the flash output is automatic. If it is still too dark you can change the flash output by adjusting the FEL (flash exposure composition) by pressing the button in the center of the dial until +/- is displayed the turn the wheel to select a + exposure (you can adjust this in 1/3 stop increments) then press the center button again. This can be found on pg 14 of the manual
Hope this helps.
1helpful
My canon powershot s3 IS is taking really dark pictures. The only decent pictures I can take with it are outside in sunlight. Pics indoors come out dark and grainy. I flip up the flash, but most of the...
This is not an answer. The S3 normally does not produce dark pictures, and I have seen this issue before. It has to do with a setting somewhere on that camera that needs to be adjusted. I wish I knew what that setting was/is as my wife's camera has recently started doing this ...
2answers
Canon550 flash problem
having the same problem, although after about a year of having it. i've come to the conclusion that the flash itself is broken, if you shake the camera you'll hear something moving around (at least that's my case) and i'm supposing it's similar to a burnt light bulb kinda thing. so the solution would probably be to send the camera to canon itself or find someone who can replace the flash (and buy one as well). I can't do either because I live out of the US =(
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
