Question about John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor
John Deere 4410 PTO error code. One long flash, one short flash and then six short flashes.
Posted by pcsappraisal on
  • Anonymous Mar 26, 2014
    where are the 4410 rear pto solinoids located ?
Kelly
  • 3,740 Answers
Check the wires on the solenoids.
http://www.tractorbynet.com/forums/attachments/john-deere-owning-operating/39426d1117768879-4410-power-take-off-stopped-665916-solenoids.jpg
Items L, M, N are mid PTO, MFWD, and rear PTO respectively
Also look at the skid plates as the possible cause of wire damage. A cheap spot / zip tie will keep the wires away from any future damage. Often the wires are damaged / torn off by a foreign object striking the Solenoid.
Thanks for choosing FixYa,
Kelly
Posted on Jun 19, 2011
Have a John Deere 4410, sometimes after about an hour of work it’ll just quit moving forward or backward, it just comes to a complete stop, but with the PTO still on and bucket works fine. Cut the tractor...
indicates a problem in the torque converter clutch set up
have the service technicians run the fault codes to determine the exact sensor failure
Aug 06, 2018 | John Deere Garden
John deere 6310 pto does not come on but i light keeps flashing even if its disengaged
Flashing pto light is an indication that there is a issue with pto. Low hydraulic fluid or a bad sensor.
Jan 23, 2018 | John Deere Garden
John deere 6310 pto not working but i light flashing
There is a bad sensor or problem with pto when flashing its letting you know to have checked out cause there is an issue
Where do I find all the Error Flash Codes for a John Deere 4410
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
JOHN DEERE 4210 4310 4410 COMPACT UTILITY TRACTOR OPERATORS MANUAL...
Nov 17, 2016 | John Deere Garden
4310 john deere e hydro
call the dealer for a service call.
Mar 12, 2014 | Garden
One long flash one shortflash five flash? 4310
I need to no where the wires go from my 15.5 h.p.kohler command charging system to the battery
Aug 02, 2013 | John Deere Seat 4210 4310 4410 4510 4610...
Where is the drain plug for the transmission on the john deere 4210 tractor
There should be a pipe type plug in the bottom of the transmission housing near the draw bar inline with the rear axle housings. Whether you have a hydrostatic drive or gear drive, the plug is in the same place. Reference # six in drawing.
Feb 16, 2011 | John Deere Seat 4210 4310 4410 4510 4610...
John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor Logo
1,477 people viewed this question
Top John Deere Garden Experts
Dennis Key
Dennis Key
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
