Question about Philips Audio Players & Recorders
How do I get the stereo sound through my tv so when I am watching my tv stations I get stereo?
Posted by stoney3707 on
Kazim ERGUNEY
  • 577 Answers
Hi,your TV automatically switches to Stereo mode and a pilot lamp comes on most TV sets.
If you want to listen your TV on your Stereo system thru your receiver, you need to connect "Audio Output " RCA jacks of your TV to "AUX input " or "Any input" of your receiver ( except Phone ) than just switch to respective mode corresponding your RCA connection..
There you go..Your TV sound is on the Receiver..
Take care and pls remember to rate me..
Thanks
Posted on Jun 19, 2011
I am an active duty soldier and i am stationed in germany. I watch alot of tv using my laptop to stream. i currently have my laptop hdmi'ed to my tv. how do i get the sound from my computer to my Bose...
there is "headphone" socket in your laptop & there is "audio input" in your tv, u need to connect both to get sound. u need a connector which has stereo jack pin at one end & 2 RCA pins at other end. please find out these sockets on laptop & tv & then buy the connector.
Sep 05, 2011 | Bose T20 Theater System
I have had the Kenwood VR-407 since 2001. I also have a Mitsubishi projection TV, attached to the receiver. When watching regular cable TV (u-verse), I can not get sound from the rear speakers. I am using...
Most TV stations you watch don't send a surround sound mix so you won't get anything in the back speakers. DVDs generally all have a surround mix which is why it sends to all speakers. What you are experiencing is normal, Bob.
Jan 04, 2011 | Kenwood VR-407 Receiver
Mitsubishi CK-32308 No sound on most stations
Turn off TV. Turn on TV, use remote to turn off SAP. Now I have sound on all stations.
Sep 12, 2009 | Mitsubishi CK-32308 TV
No sound on my Sony Triniton - video has SAP on it
YOU ARE IN SAP MODE. IF THERE IS NO SECOND AUDIO PROGRAM ON THE STATION YOU ARE WATCHING YOU WILL GET NO AUDIO. SWITCH SAP TO STEREO OR MONO. SOME REMOTES HAVE A MTS BUTTON ON THEM.
Jan 09, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No surround sound when on TV mode
You may have to set the TV output to stereo or matrix out. Also if the stations are not in stereo or surround it will not play in surround.
If you are connecting to a cable or satellite box and you are just using the coaxial input to the TV you may not get stereo. Some cable companies only send mono signal through the coax and you need to connect the tv to the box using component cables and the R and L audio connections.
There may also be settings in the receiver that you have to adjust to get surround from the TV.
You could connect the audio out directly to the receiver instead of the TV and just use the receiver for TV sound.
Hope this helps
Cheeres
Jan 01, 2009 | Audio Players & Recorders
Stero SAP
Go to tv setup in the tv menu and turn off the SAP.
Sep 02, 2008 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
TV Sound through stereo speakers while watching tv.
All the above connected method is correct. Need to change the option in the stereo system as md or auillary depends upon the model. Go through user manual for stereo system.
May 27, 2008 | Sony KV-35S42 35" TV
No sound
have you checked the connections and what is hooked up to the tv do you use a receiver or surround station to produce sound and did this just happen? please more info.
May 27, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
TV trouble
Option called SAP has been activated.....in audio menu...
select stereo, not Second Audio Program................T.
Dec 19, 2007 | RCA F32650 32" TV
Mono/stereo flashes in upper left tv
The mono/stereo is an indicator of the audio signal that the TV is outputing. Like most car radios, they have an indicator that tells you when a station in coming in clear, which may be just an LED or a light. When the signal is weak or when your on a non-stereo station the indicator will not be on. What signal are you providing to the TV? Cable, OTA, STB output??? low RF signal level could be the cause for this.
Mar 18, 2007 | iLO 3200 32 in. LCD Television
923 people viewed this question
Top Philips Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
