Question about Sharp AR-5316 Advanced Digital Imager Copier
Ma photocopieur shar 5516 marque un message d'erreur H4
Posted by issaseynisou on
Victorman
  • 846 Answers
H4 error indicates the fuser is faulty and should be replaced.
Posted on Jun 19, 2011
rakshita_sl
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
My AR-5516 printer is not detecting by the computer, interface pwb is perfect. pls help
Posted on Jun 23, 2011
How can i resolve Erreur E000020-0125 pour photocopieur canon IRC 4580i
SALT sensor(replace it or clean window),replace the drum unit,clean or replace ITB unit.Concerning the first two digits of detail code:01-Y,02-M,03-C and 04 Bk.So in your case the problem is in yellow unit...
Sep 26, 2014 | Canon Office Equipment & Supplies
Bonjour, ma riso ks800 marque l'erreur de E4 .Pouvez vous m'aider pour la resoudre SVP? merci d'avance!
HI. E4 REFERS TO "INK OVERFLOW" . CHECK INSIDE THE DRUM, AND CLEAN IF NECESSARY. IF YOU NEED MORE INFO, LET ME KNOW :)
Apr 16, 2012 | Riso RZ390 Duplicator
Lorsque je demarre ma camera il affiche un message erreur lens
Sacrebleu!
C'est parce que le
m?canisme d?licat est endommag? et l'objectif pouvez pas d?placer ou lock en position correcte.
Jun 30, 2011 | HP Photosmart M425 Digital Camera
MON PHOTOCOPIEUR AFFICHE LE CODE ERREUR L 6 SUR LE PHOTOCOPIEUR SHARP AR-205 DIJITAL QUE DOIS-JE FAIRE
L6 = Polygon Motor Lock Detection
Polygon motors are not serviceable items.
Try switching the machine off/on. If the code doesn't clear then you will need to get the motor replaced. Quite often the motor will have made a screeching or rattling noise before it fails.
Hope this helps
Feb 09, 2011 | Sharp AR-M205 Copier
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
BONJOUR DEPUIS CE MATIN QUAND JE METS MA r4 J AI UN MESSAGE D ERREUR SYSTEM ERROR PLEASE CHECK NDS SYSTEM DATE
Change the date back before 14 april and you can play again.
To resolve this problem update the firmware of your R4 card.
Apr 14, 2010 | Nintendo DS Lite Console
Minolta di 181 error code M4
QUEL EST LA SOLUTION POUR DESACTIVER L'ERREUR CODE M4 ?
Jan 21, 2010 | Minolta DiALTA Di181 Printer
Ma photocopieuse affiche H4
salut ! le code H4 c'est une erreur qui vient du fuser ( la ou le papier passe et les rouleaux deviennent chaud)
Il faudrait checker la lampe de chauffage et voir si elle est intacte,
la deuxieme possibilite est le fuse de prevention de haute chaleur, (thermofuse)
L'une des deux est votre probleme. Salut, et Bonne Anne.
Dec 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
Solution ?  ,mon erreur E000019-0000
j'ai un problème avec ma IR 3300 il affiche un code E 248-002, que faire? aide moi SVP!!
May 05, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Sharp AR-5316 Advanced Digital Imager Copier Logo
471 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
