Hi
For downloading the driver for thinkpad 2647 click hear, select your Brand, Family, Type, model and last is operating system, after download the driver, go the that folder and select the setup.exe and install the driver, when installation of driver finish reboot your computer.
If my solution fix your problem give me thumb
"Cheer "
Hello download your drivers from here www.ma-config.com
Where can i find a hard drive system for my thinkpad 2647.
SOURCE: free ibm t21 2647-4bu restore cd download.
i have problem with my t21, it always hang up after several minutes,dont know what makes it freeze,it happens after i installed xp prof. help please
If your system is working and you can get the internet on it then you should be able to access all the required driver updates available via the Lenovo web site here :-
http://www-307.ibm.com/pc/support/site.wss/product.do?subcategoryind=0&familyind=50268&brandind=10&doccategoryind=0&modelind=79050&doctypeind=9&validate=true&partnumberind=0&sitestyle=lenovo&template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&operatingsystemind=49979&machineind=78825
This Address is specifically for your machine type model.
SOURCE: i need vga driver for my IBM Thinkpad T23 notebook
Use this link http://www.lenovo.com/support/
1- Select your Product - Notebook and Handhelds
2- Select family - Thinkpad T23
3- Select Your type
4- Select your Model
5- Select your Operating system
And Download and Install
Have a nice day...
SOURCE: IBM thinkpad 2647 T21 LAN Card Driver files needed...
if you are using the internal LAN card to connect to the cable modem, no additional drivers will be needed. However, you would need to configure TCP/IP settings to use a DHCP server to automatically configure the IP address. you would also need to check whether or not you have the right CAT-5 cable. you might need to buy a crossover cable.
hope this helps
SOURCE: Searching for LAN driver for R40e IBM thinkpad
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-46024
There u go M8!
All avalible drivers for that R40e of yours:)
Good luck
Nic
go to this "Website," and "Fill-in" or {Choose} any information needed to get the "Drivers" you need. Than you'll be able to "Download the Drivers."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Click here: http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do?country=us
