HI! My dishwasher will not turn on - it shows a flashhing light on the finished button and the start button beeps everytime I press it on any setting. I have opened and closed the doors, filled salt, emptied filter, checked water supply and turned off/on mains electicity. It has done this before and somehow I got it going again but I don't know how. Any suggestions?
Thanks
SOURCE: Indesit idl 705 Dishwasher
Having read another users fault (LUNNY) that has same fault. They got engr out and it was a blocked pump. Where is the pupmp located on this model as I have the same fault and want to resolve it asap.
SOURCE: Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I've had the same problem on my Indesit (IDL-730, IDL730) and after pouring in salt until full for ages, without the light going out, I finally decided to do the reverse.
I left it to run down the salt over a couple of months, until well empty (not ideal, but I was getting desperate!), and then finally refilled it.
Problem solved - salt error light was no longer on
All I can figure is that a blockage had set in and casued the issue. Leaving it to clear over time sorted it.
Hope this helps in your situation.
SOURCE: Indesit dishwasher sump keeps filling up with water when turned on
I had a similar problem every time i bailed the sump out by hand and turned the machine back on it would fill the sump or just shut off.
Having spent ages checking various site it boiled down to one of three things there is a thermostat switch underneath they are know to go on the indesits and cost next to nothing to replace
second cause and most probable is to take machine outside before you do this front cover below front door removes to give access to pump you ll know it the pump because it has a pipe rinning into it and one out on my indesit i turned it upside down and got really easy access to it comes of easily take it to pices bit by bit really easy probably need small allun key depends on model check put for foreign objects , spinx blackpool rock etec etc only kidding it might be a bit of plastic or something that stop the spindle turning freely inside the pump if you find anything clean put back and off you go if pump is knackered you can get them off the web for 4.95
last but not least is the problem that mine actually had in the end and the easiest to fix `water pressure` if there is insufficient water pressure the machine regognised this and activate a shut off valve the machine lights flash you can reset the programme but it still does nt work. take the water pipe off the back put it into a bucket and open the valve you ll now what good pressure looks like mine was poor when i took the adjacent kitchen unit out it transpired a shut off vavle had been placed on the pipework the vavle had never been opened fully by the plumber and was restricting the water supply . take your time dont rush and be methodical take advantage of a local parts supplier ash them what most repairers will do first. it can be very rewarding to find that a/ you can do it and b/youve saved 60 or 70 quid in the process.
ps never mess with the machine whilst connected to the mains or spiky hair might come free with the repair and do take the machine outside or you ll have water evrywhere trust me
SOURCE: Indesit IDL 530 Dishwasher
Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
SOURCE: flashing green light on my indesit dishwasher
Put some towels dowm and tip the dishwasher over to one side about 45 degrees, if water pours out of the base it means that the dishwasher is in "flood mode" and you have a leak into the base that will need resolving.
Thanks
