Hello
It is due to a software error. Reset the device and install the latest sofftware update from Navigon website.
Hi there, I did some research and found that the navigon 7100 has a lot of bugs, which has now motivated the manufacturer to come out with an update fix that should get rid of this error.
Here is one of the many examples of the error:
"Fatal Application Error!
Application MN6.EXE has performed an Illegal Operation and will be shut
down. If the problem persists contact the program Vendor.
It requires that you install the updated software to your sd card. The best way to do this is download the software off the site, back up your previous data on your sd card to your computer while you connect the sd card using a sd card reader. You can buy one at any electronic's store almost if you don't already have one. Then go about installing the new updates and everything should work smoothly again.
Here is the software location, remember to sign up, sign in, then click on the link for software updates.
https://www.navigon.com/site/us/en/my_navigon/unauthorized/products_us
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
SOURCE: Navigon 7100 Fatal Application Error
I have same problem I went to their website. www.navigon.com/site/us/en/my_navigon. In there you register your device and also in freshmaps put your Freshmaps code to activate.once activate download updated software from the windows of maps and software in Navigon 3 windows.You will find picture of your device hit on that picture to downlaod software update in your computer to save to your desktop.It will take atleast 45 to 1 hour depend on speed don't turn off cmputer in between.
Than get 4 gb sd card put to slot to your computer either directly or through Card reader whichever it suits you .when card is in computer wait till it shows removable media inserted.
Than hit on icon on your computer desktop where you downlaoded software update, mesasage box will appear to download to sd card hit yes it will download entire software wait till it says downlaod complete.
After download complete go back to same website and hit on window says software updates hit on that and it will downlaod most updataed version of software to sd card.
After completion of downlaod completion romove sd card be carefull to check on that says eject sd card hit on that than remove the card after otherwise it will destroy the pogram in sd card.
Put your sd card to device and there you go it will work.
Since new software is large and it requires more space than old one ols card will not work even after download of new software.Please buy 4 gb sd new card and follow the procedure.Since new software consumes almost 2 gb I recommend to purchase 4 gb sd card .please don't buy micro sd card with adapter it won't work.
I have already done this it says software is up to date but it still gives me the error. I updated them on the website and checked the disk also on freshmaps.
DID ALL OF THIS BUT IT STILL DOESN'T WORK
