Question about Canon imageRUNNER 2270 Copier
My Cannon ImageRUNNER 2270 is not printing the entire page. It is cutting off the top quarter of the page. I have changed the margin settings and it is not doing anything different.
Posted by kolinadallen on
Paul Pettit
  • Canon Expert
  • 270 Answers
Check to make sure that the paper size dial on the paper cassette is the same as the paper size in the cassette. Portrait or landscape? I don't know whether you use American sized paper but the dial Must be LTR ( front to rear orientation of paper ) or LTR-R ( Left to right orientation ). I know of no other reason for the problem.
Posted on Jun 19, 2011
How do I fix Canon IR2200 not printing whole page. Large margins on top and cutting off bottom of page.
It sound like the paper tray is not set correctly. Probably set to landscape and trying to print portrait.
Jun 12, 2014 | Canon imageRUNNER 2200
My Business Cards
You need to set the print size to match the size of the card.
you either need to resize the document or change your print preferences to match the size of the card.
May 16, 2008 | Avanquest MyBusinessCards (824592)
The printer cuts off the top part of the document when printing. Is this a margin issue?
Yes, most likely your application's margin settings are incorrect. Try printing a test page - NOT from the application. If this is Windows, go to printers in control panel, right-click on the subject printer, choose Properties, then click the Print Test Page button. You should get the standard Windows printer test page with the logo at the top and all the printer specifics below. If the test page is also cut off, look around in the HP-provided software for any margin and/or page size settings that are incorrect, such as A4 paper when it should really be Letter size.
Feb 18, 2011 | HP Officejet Pro L7680 All-In-One Printer
My Canon ImageRUNNER 3225 does not print correctly aligned when sent through the feeder? When feeding paper, I have tried Landscape and the resulting copy is cut off from the top and bottom and the left...
Is it ok when you just put the document on the glass? If so, the Document feeder needs a whole set of rollers.
Otherwise the document scanner may be bad. This needs to be changed out by a technician.
Whit
Item, Inc
Sep 15, 2010 | Canon imageRUNNER 3225 Black and White...
How do you set it to print in LTR instead of
Inside the paper cassete there is a dial were you can set your papersize.It is a blue manual switch switch it to LTR instead of LTR -R.There is also a document stop that you can remove to set it to the correct paper size.If you print from your document select portrait insted of lanscape.
Thanks for your support.
Dec 28, 2009 | Canon imageRUNNER 2270 Copier
Printing document
Did you change the top margin setting?
Make sure that the paper size is correct in the printer settings of the control panel when you print. You have to tell it what size paper you are printing on.
Aug 15, 2008 | Sharp AL-1551CS Copier
Right Margin Does Not Print
This one work for me...on top left of the page click on file then click print. A box print with option opens...... click options then select or put a check on left bottom box that says print all linked documents....good luck!
2nd option or
Last option and 100% will print the entire page even allows you to select what you want to print inside the page. Its called webcollect and here is the link.......http://www.web-collect.co.uk/
Mar 21, 2008 | Canon PIXMA MP470 All-in-One Printer
Canon Imagerunner C3200 - printing problems
check the feeder rollers and make sure they are grabbing the page at the right time. Sometimes rollers cna get slick and spin for a moment before picking up the paper. This can cause the timing to be off when the page is fed through.
Mar 06, 2008 | Computers & Internet
Canon imageRUNNER 2270 Copier Logo
422 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
