Question about Radio Shack Accurian APD-3955
How do i fine parts i need acadapter for my dvd player
Posted by william664 on
Jdvillanueva
  • 2,098 Answers
I'm assuming that your unit is Accurian APD-3955. Please click this LINK to buy online for an AC Power Adapter.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Jun 19, 2011
Mustek dvd bttr chrg
I am sorry but we have no parts resources other than googling the part/type number off the battery pack. I suggest you just google that and i am sure you will find what you need.
Jun 21, 2012 | kawasaki PVS-10921 Portable DVD Player
DVD player doesn't work
you can open the top cover and take the cd out.
Jun 04, 2008 | Sony SLV-D350P DVD Player/VCR
Tip
My dell pa 12 won?t start ?
When i start my dell pa 12up and it takes 10 mins to load to windows XP, , when the windowsloading screen comes up the FANS go crazy. I then wait till i’m at thedesktop at which point i immediately shut down the pa 12(which takes afurther 7 mins) while the FANs are going crazy.
answer :
Now if i start the pa 12 again it works normally.
I had to do this procedure everyday, untill today when i switched the pa 12 on, waited till the desktop appaered and i removed the battery while the pa 12 was on..
Now when i switch the pa 12 on it powers up but i’m not getting anything on the screen
First try a different AC adapter (such as :pa 10 ac adapter)
If no change then the issue is the motherboard. Often the AC adapter will fail then the battery discharges and you get the symptoms youdescribe.
SO AC adapter then MB
It shows no power on your laptop but it shows you the dvd player led comes on then off.
I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter (hp dv6000 ac adapter)tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If laptop AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
on Feb 09, 2010 | Computers & Internet
No pawer up
Hi this is vinod. You said computer is not powering on. So first thing if it is laptop or netbook. check the walljack if it is working or not. or try with another. Acadapter brick cables so check the connection on either side of it. if fine check if any led or light glowing on the brick. if it is still not working. slightly vigil the acadapter where it is connected to the acadapter. if still doenst . check the pin in the port is secure or not. or acadapter pin is secure or not. if no go. check with battery if has enough charge. if no go
conact emachines support. it can be motherboard issue as well.
Apr 21, 2010 | E-Machines M5312 Notebook
Dvd can't read dvd but works fine in all cd's
your lens of your dvd is not good need to replace it the parts 100% sure.([email protected])
Mar 10, 2010 | Lite On LVC9006 DVD Player/VCR
Acer 5920 aspire wont start
3. Connect the AC Adapter for laptop to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
I replace ac-adapter because it had a break in the wire it kept telling me battery was low but it's a new battery,it was was running just fine before this happen.what can i do to get back up and running....
Check the laptop if it is running only on the acadapter alone. If it does do the battery health check from hp.com with the battery plugged in and the acadapter too . This should be a problem with the internal pin .
Oct 18, 2009 | HP Pavilion zd8000 Notebook
I need a Coby TF-DVD7006 DC adapter
acadapter.com, lcdpayless.com, ebay, are just a few that I can Think of.
Sep 30, 2009 | Coby TF-DVD7006
Dvd player stopped working
NEED REPLACED DVD MECHANISM UNIT
Manufacturer Panasonic Part Number LSXK0118 Description MECHANISM
Sep 12, 2009 | Panasonic Televison & Video
Radio Shack Accurian APD-3955 Logo
Top Radio Shack Televison & Video Experts
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
