Master
- Posted on Jun 19, 2011
Re: Just received my new cobra 29 lx cb. When I turn on...
- Check that power cord up by the tip. It is possible it is a little loos in the tip (that hooks into the radio) Being new it almost has to be related to the power feed.
- Make sure the fuse you are using is good. Use a 4 amp fuse in there.
- Make sure you installed all the shoulder washers in your antenna properly or this will cause a short too.
- Your power supply could be at fault too. Take a multimeter and turn it to DC volts and make sure 13.8 is coming out of it. The power supply could be failing under a load. Have you tried a quick setup in the car? See if sticking the power cord pos to pos and neg to neg on the car battery keeps the radio running better. You don't need to have the antenna hooked up for this just DO NOT key the mike. Just long enough to see if the radio stays on for more than 2 seconds.
- If you do all this testing and the radio still cuts out then you have a defective unit and it needs to be replaced with a properly running unit.
- Hope this helps and thank you for using FixYa.
Regards,
Tony
