I have a magic chef oven the model number is 439w 3w, i need new burner knobs and oven thermostat knob, i need help trying to find them. Can you please help.
Re: I have a magic chef oven the model number is 439w 3w,...
Hello, Thank You for using FixYa. I will be helping you today.Assuming the model is correct here you go http://lookup.bellparts.com/lookup/13830/76035
Thank You and please rate my answer if it was helpful..
Is there an orange glow in the burner area when this happens? If so then the thermostat is not shutting the ignitor off and needs replacing. If there is no glow then the gas valve is not shutting off the gas and needs repalcing
Try Google your manufacture name model # and the word parts. This will not correct your lighting problem. It sounds like you have a igniter switch problem.
always unplug electricity before attempting to repair on any electrical appliance
In the US, there is a parts distributor with locations all over the country. Their number is 1-800-482-6022. They have four of your burner knobs (part number 74001253) in stock in the Fresno, California warehouse. The cost per knob is $9.27 US. I can't say how much the shipping would be, but they use UPS and FED EX.
Good luck....and good day.
The only two things you can do are pull the core of the oven thermostat and re-grease it, but that could throw your temperature calibration way off. The other is to replace the thermostat. Either way, a calibration is probably a good idea.
I have an old Universal Chef stove - we are replacing - it is probably a mid to late 60's - the oven pan is warped - otherwise it works fine - burners, knobs, grates etc. are good - willing to let go cheap - contact Chester Koch 573-898-5508 (Elsberry, MO)
thromo stat bad the tempature knob has a gas valve attached to it along with two gas lines you will have to remove the oven to acess all lines as they run on the backside of the case remove the burners and gas input line copper line remove gas supply tube to all burners remove valve and take to dealer they need the numbers off the vavle for exact repacement not just the numbers off the stove itself east fix with simpl hand tools thermost has a themocouple attached to burner assembly and this is your problem bad part is themocouple is built into thermostat and is no serviceable only fix is to replace "thermostic gas valve"
