Sony BRAVIA  KDL-46V3000 Television Logo
Anonymous Posted on Jun 19, 2011
Sony Bravia 46 inch model number KDL-46V25Li, does not work, blinks 4 times. What is the problem?
5 Related Answers
Anonymous
  • 4234 Answers
  • Posted on Jan 05, 2009
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Anonymous
  • 86 Answers
  • Posted on Mar 25, 2009
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Anonymous
  • 93 Answers
  • Posted on Sep 11, 2009
SOURCE: sony bravia 46 shutting off a blinking 6 times
here's blink codes for sony bravia
1 blink abnormal AU Power Voltage
2 blink abnormal d5v/a9v power voltage
3 blink Abnormal panel voltage
4 blink backlight failure
5 blink abnormal main power voltage
6 blink abnormal speaker voltage
7 blink internal temp. rise
8 times ic5000
that helps?..
Testimonial: "Cheers for the help it maybe the was i have the surround sound hooked up thanks heaps "
Anonymous
  • 117 Answers
  • Posted on Nov 11, 2009
SOURCE: Sony Bravia TV, stays on standby with a flashing
power supply/ in uk look up ohm supplies to repair it
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Aug 19, 2010
SOURCE: I need a replacement screen
You can try contacting www.shopjimmy.com
It will be more than the TV is worth, better off selling the TV for parts on EBAY, then use the money toward the new TV. LCD panels are limited production run, and it is the most expensive of the whole TV.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
What does 4-blink error code indicate?
These may help - the first just tell what it is and which ICs maybe the problem (quite technical)
Solved Sony Bravia Blinking Code
Bravia KDL46EX720 Red LED blinks 4 times and TV wont turn on What is the...
or, in the last resort you could try Sony support, either to get a service manual, or to ask a technician. Don't be fobbed with an expensive answer as in one the examples above.
Support for LCD TV BRAVIA Sony
18.November.2015
My sony bravia model number kdl 46ex723 blinks four times what that mean
Solution for Sony Bravia KDL 46EX723 blinking red light 8 times. Information below is from Sony online support, it worked for me:
Please disconnect the Internet connection from the TV and your TV will work fine.
We are suspecting a network outage issue on Sony device, we are currently investigating this issue. I am really sorry for the inconvenience caused.Unfortunately we don't have any ETA on this,I request you to try at a later time.
Bravia 52
need the model number of your sony in order to assist with the diagnosis. Please respond to this same post for assistance.
1helpful
Problem with Sony Bravia 46" TV (Model
blow out fan in mother board tower mother is over heating and not geting enough of air leting the mane chips over heating makes computer stop so it doesnt catch fire.
7helpful
2answers
I have a 2008 Sony Bravia KDL-46W4100 that when I turn it on the red light blinks 14 times. Please help me troubleshoot this problem so I can order the correct part to fix this...
Please help me troubleshoot this problem so I can order the correct part to fix this television
I have a 52 inch sony bravia. turn it on and i hear a buzzing sound then the red standby light blinks 13 times.....what gives. I need help
Sounds like the lamp is blown. Check your manual to see what the blinking lights mean and how to check the lamp.
Moving country with Sony Bravia KDL-46W4100
What is exact model number of your Sony TV to check its specifications that it will work on 230V 50Hz
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
