Question about Allen & Heath Allen and Heath GL2400-32 32-Channel Mixer
I have a A&H GL2400 - 32 ch.Console; How do i hook up (5) Effect units to the Console?
Posted by beezmusic on
Mosh
    New Friend:
  • 41 Answers
Is this for live sound? You can use your aux outputs as sends if you're not using them for monitors and return to spare channels. If any units are being used for only one channel, either run them in-line (use the effect unit's wet/dry settings) or use the channel's direct out and return to a spare channel.
If one effect is applied to several channels you could put those into a sub group, take that sub output to the unit and return the 100% wet mix to a spare channel.
Be careful not to send the return channels back to any auxiliaries you're using for effects.
Posted on Jun 19, 2011
How do you use a four way footswitch
Need more info. What kind of foot switch and what are you hooking it up to. For guitar they are used for switching distortion to clean on 1 switch, one for reverb, one for chorus, and possibly 1 for bypass. All depending on the amp you use, and what effect the amp has built in it. Some amps only have clean and destortion which make the other channels on the footswitch useless. Hope this helps.
Dec 31, 2014 | Music
Line 6 how do i get it to work
Line 6 connected to AC power and LED showing power to unit. Guitar into effect input, effect output to guitar amp. Does guitar make sound through amp in bypass mode? No then check cables...yes then use foot switch to turn Line 6 effects unit on. Adjust control knobs for desired effect levels/settings.
If pedal provides no effects...off/on switch defective or internal electronics in need of repair.
Oct 26, 2012 | Line 6 DL4 Delay Modeler Effects Guitar
Could you use the Bose 901 series VI for a pa system?
Actually that's where the bose 800 systems came from.
Old school jazz guys were using their 900 series turned backwards as a pa
Mar 31, 2017 | Music
How do I hook up my mini Kaoss pad as an effect pedal for my guitar?
Depends on if you would like it to be an in line or sidechain effect. Easiest way is that the kaos pad should in qtr inch jacks that say in and out. Plug guitar into in and come out of the "out" to your amp. Not how your using it? Message me and we'll figure it out for ya.
Sep 19, 2011 | Music
I would like know how to connect FBQ1502 to Mackie miixer
come out of the mixer with your main outs ( L/R ) and go into ch 1. ( l ) and ch. 2 .(r) and them come out of unit to your power amp and power amp to speakers.
Aug 26, 2011 | Music
I've only had my Marshall MG102FX combo a few months and I love it, but lately it has been cutting out while I'm playing, towards the end of our set (normally about 2 hours after switching...
NEVER CONNECT PEDALS THROUGH THE EFFECT LOOP OF AN AMP. They are NOT design to work at the same signal levels !!! ONLY use effect units that are design to be used in amp effects in the amp effects loop/
Aug 01, 2011 | Marshall Amplification Marshall MG102FX...
I purchased this light in August of 2010. By November of 201, the bulbs began to flicker off and on. I replaced them with new bulbs and the same thing is happening. Is there something I can do to get this...
VERY COMMON problem of the bi-pin Halogen lamps... The SOCKETS are subject to very high heat and lose the temper of the spring contacts which heat, oxidize and fail. It is a FATAL thing with the sockets. They have to be replaced.
Here one source for sockets... remember to get one for your particular lamp... this link is for a particular base so you may have to go to the home of this company.
http://www.frontierlighting.com/product.jsp?part=44766&process=search&show=&&gdftrk=gdfV22514_a_7c834_a_7c3267_a_7c44766
ALSO search Ebay for "socket XXXX" where XXXX is the lamp number.
Feb 28, 2011 | Chauvet Ch-258 Cyborg Light Lighting...
I'm not satisfied with the built in effects of my PMP 5000. Can I hook up an external effect and if so,how.
Depending on whether you want the external effects to be on everything or just a single mic input, you connect them to the power amp "insert" or the insert for the mic you want it on.
Looping it out on multiple mics would be tricky, but you could send the units effects into one of the monitor outputs only by selecting a "non-effects" setting in the unit and sending internal effects to one of the monitor outs, and then looping it back into another input to join the mix.
Aug 23, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Set up my two 15"mains/ and one 18"sub.
This unit will put out around 400 Watts a side. PLENTY !
If you want a sub, either get a powered one or an amp for it and run off the MON output.
CAUTION: NEVER permit the speaker cable to be removed or interrupted whilc power is on... you will arc out the rear most amp in the unit... I know... I fix them... There si a bit of weak insulation that can arc through on a circuit board.
If you ever have a fuse blow, DO NOT replace it, you will do further damage inside the unit... take it for service.
Apr 13, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Allen & Heath Allen and Heath GL2400-32 32-Channel Mixer Logo
504 people viewed this question
Top Allen & Heath Music Experts
Marvin
Marvin
Are you an Allen & Heath Music Expert? Answer questions, earn points and help others
