Question about RCA D61W20 61" Rear Projection Television
I've replaced cp150 cp120 cp114 capacitors and now it turns on for about 2 - 3 min and then turns off what else could it be? rca d61w20
Posted by juliorodr843 on
  • juliorodr843 Jun 19, 2011
    Only the cp150 had a leak on the bottom the other cps looked ok but I changed them anyways also I resolder the flyback and it was working well for a couple of hours and then turned off by itself I wait for a couple of min to turn it back on and it will but only for a min or 2 what else could it be?
Sonny Berry
  • RCA Master
  • 8,617 Answers
It could be the flyback transformer or several other items all on the deflection board. Were any of the caps you replaced domed up on top?
Posted on Jun 19, 2011
I have a RCA d61w20 that on first turning it on it takes for ever the power like blinks then after about 10-20 min it turns on and is fine all day as long as you don't turn it off
thats usually caused by failed CP150 CP120 and CP114 capacitors. You can get the RCA repair kit by that same name from www.tvrepairworld.com which also contains the repair instructions and replacement capacitors.
Mar 07, 2012 | RCA Televison & Video
My rca d61w20 rear projection television will not turn on. green light indicator will come on for 5 sec. then go out. any ideas?
Replace the CP150, CP120 and CP114 capacitors you can get the RCA repair kit by that same name from www.tvrepairworld.com which contains the caps and the CD with instructions.
Feb 17, 2011 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61 in. Rear Projection Television blinks three times when trying to turn it on then quits blinking and the television will never come on. What's the problem?
Most likely its the CP150, CP120 and CP114 capacitors. You can get the repair kit with that same name from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Jan 08, 2010 | RCA D61W20 61" Rear Projection Television
The Tv we have is the RCA D61W20 and it wont do anything it will not power on. What should we do?
Its most likely the failed capacitors CP150, CP120 and CP114. You can get the repair kit with that same name at www.tvrepairworld.com the kit also contains the CD with repair instructions.
Jan 07, 2010 | RCA D61W20 61" Rear Projection Television
Rca d61w20 wont come on
CK capacitors on Deflection Board cp150 2200uf 16v if puffed up on top it is bad so replace cp114 and cp120 / 220uf 325v.
Feb 10, 2009 | RCA D61W20 61" Rear Projection Television
When set cold it doesnt have pic
check capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is Bad so replace other 2 as well.2200uf 16v and Two 220uf 35v.
Jan 15, 2009 | RCA D61W20 61" Rear Projection Television
Can't turn on tv
Check capacitors cp150 2200uf 16v and cp114,cp120 220uf 35v- If cp150 is puffed up on top replace all 3 capacitors.
Jan 13, 2009 | RCA D61W20 61" Rear Projection Television
RCA D61W20 Projection TV
On the Deflection Board CK 3 capacitors cp150 2200uf 16v cp114 cp120 220uf 35v If cp 150 is puffed up top then it is bad so replace all 3 capacitors. Resolder all pinns on FBT too. and make sure second ribbon connector is in good.
Jan 06, 2009 | RCA D61W20 61" Rear Projection Television
61" RCA Projection TV Model #: d61w20
You could have shorted Yoke and if so you have to replace all 3 yokes another thing that can cause this is Capacitors on Deflection board cp150,cp114,cp120 If cp150 2200uf 16v is puffed up on top then it is bad ,so replace all 3 caps other 2 are 220uf 35v.
Jan 02, 2009 | RCA D61W20 61" Rear Projection Television
3 green lights flashing on rca d61w20
On Deflection board cp150 if it is puffed up on top it is bad ,3 capacitors cp114 cp120 they are green with gold writing on them But; if cp150 looks ok Then you have problems in SSB board its the one that has tuners on it/ where you hook your cable too. The board to the left of it is the deflection board.
Dec 23, 2008 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
