LG 42LC7D-UB Television Logo
Posted on Jun 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a sony blue ray DVD player and when I connect it via HDMI cables into either HDMI1/DVI or HDMI2, i get the message invalid format. I've tried multiple cables, multiple LG TV's, and the it works everywhere except this TV. I'm at a loss. HELP!
Chi Chu
Level 3:
  • LG Master 8,457 Answers
  • Posted on Jun 18, 2011
Chi Chu
LG Master
Level 3:
Answers
8457
Questions
0
Helped
2822654
Points
26282
Tries tv unplug,replug it back like about an hour later.Than tries go into the tv menu do a resetting to factory setting in every settings on the tv.Than reconnect the Blu Ray player again should work.If not the tv and Blu Ray player softwares main firmware just not compatibles.The only solution is just don't used it on this tv,because if u tries to upgrade the tv firmware or the Blu Ray firmware and u get the wrong upgradable version in the tv or Blu Ray player.That it u in deep ****,than the tv or Blu Ray player well not functions at all or have multiple orperational problems during it playing times.
Sony KDL-40NX711 HDMI PORTS STOPPED WORKING. EVERYTHING ELSE WORKS FINE. WHAT WOULD CAUSE THIS TO HAPPEN?
Sounds like everything works. Your remote has an input menu. Have you cycled it around to the right component? i.e. HDMI1 or HDMI2, or DVD, even PC?
If not, try that.
Hdmi connection blueray to sony tv bravia.sony bd. pluged to hdmi2 unable to get picture. hdmi1 being utilize by cablebox. should i change hdmi setting on tv, how is that done.
there should be a imput button on original remote. just push it then scroll to hdmi2, then enter should give you picture if not they will be an imput option under your menu options
No picture when tv powered on
When power on and input set to hdmi1, there is no image appears
When connecting motorola dct6412 to samsung tv, blu-ray player & avr via HDMI (DVI), do you run the HDMI from dvd & cable box to the avr, then seperate HDMI to the tv?
If you have more than one HDMI port on your TV,
run one HDMI cable from the DCT6412 to the TV,
and one HDMI cable from the BluRay unit to the TV.
Then, use the "source" (or "input") control on the TV's remote-control to select either 'HDMI1' or 'HDMI2'.
2helpful
2answers
I have an LG 42LC2D TV with INVALID FORMAT ON HDMI2
I have had this same issue.
Problem your tv isnt true 1080p meaning it will not work however when you switch to componet cables goto menu then change the display settings to 720p or 1080i then your HDMI connection should work fine.
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Sony bravia kdl40l4000 hdmi issue
i have sony bravia. i couldn't connect to my ps3 with hdmi cable. but i get only audio. i think it is with the tv settings. can you help
No HDMI video signal to projector
cheak out put on samsung to set it at 720 hdmi out ect might nee dto use red green blue or s video to see menu
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
