Have a look
here for info about the Ranger 2950. This is an Amateur 10 & 12 meter transceiver that enjoy some popularity due to its ability to be modified to work on the 27Mhz Citizens Band.
Make sure the Mode is set to something other than PA. A few of the first things that come to mind is the Volume, Squelch & RF Gain settings. The Volume is straight forward - choose a setting in the middle to begin. Next, set the squelch. Most radios have the squelch open when set fully counter-clockwise. As you move the squelch to this position, sound should be heard from the speaker if a signal is present. As long as there is an antenna connected, the radio should "hear" noise. If you do not hear anything, leave the Squelch fully CCW and try varying the RF Gain fully in one direction. If you still hear nothing, set the Squelch to the fully clock-wise position. Adjust the RF Gain to the opposite direction. At this point, you should have heard something - even if just static hash. If not, the volume control may be dirty. Disconnect power and rotate the volume control back and forth several times to dislodge any dirt on the volume wiper inside the radio, and try again.
Make sure that the Ext Spk jack does not have a plug inserted as it will defeat the internal speaker. Likewise, if using an external speaker, make sure it works.
Do you mean mic gain is full clockwise?
