Question about PfaFF Sewing Machines
Skips a few stitches when using a double needle. I'm using a recently acquired old Pfaff Hobbymatic and have used a double needle before on a Singer. When I tried sewing, it will stitch but then skip a few on one of the needles and go on then skip a few then go on and etc. I tried re-threading and adjusting the tension but the problem keeps continuing. Any suggestions will be greatly appreciated. Thanks!
Posted by coolsoundmin on
Tally Girl
  • PfaFF Master
  • 1,134 Answers
Firstly are you using a regular twin needle on a knit fabric? this could cause skipped stitches.
is the twin needle quite old and possibly blunt?
Is the Hobbymatic a model that requires a slanted twin needle, there are two types of twin needles as the computerised machines need the offset style. You can distinguish between them by the plastic block on the needle shaft where the twin needle points are set, either red or a deep brown colour.
If none of the above apply, then it is possible that the timing sequence is slightly off so that one of the needle's thread is not getting caught during the stitching.
Timing is an adjustment that I leave to the technician to address. But if you want to have a go yourself there may be some videos on you-tube for your model and how to make this adjustment to it.
Posted on Jun 19, 2011
I'm trying to find needles for my Pfaff Hobbymatic 875. Haven't had any luck. Do you know where to buy them? Thanks.
The Pfaff Hobbymatic Extra 875 uses standard 15x1 sewing machine needles. The needle you need will depend on the fabric and thread. You'll use a thicker needle for denim than for a lightweight knit. See https://www.sewingpartsonline.com/pfaff-875-serger-machine-parts.aspx?index=14 for a wide selection of different in stock needles.
I hope this helps.
Apr 18, 2018 | PfaFF Sewing Machines
My pfaff hobbymatic 875 is skipping thread on the bobbin side
Be sure to use a brand new needle. If the needle is bent or damaged, it will frequently skip stitches. Also, if you are using the incorrect needle for the fabric & thread you are using, it will skip stitches, ie a ball point needle on woven fabric.
All About Needles
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Oct 21, 2016 | PfaFF Sewing Machines
I have a Pfaff Creative 1475 CD. It only skips stitches on stretch materials. I have tried a ballpoint and stretch needle and it still skips stitches. It sews a 100% correctly on any other type of...
There are a couple things you can do that may help. 1. Float some lightweight paper under the fabric. Sew through the material and the paper. Then tear away the paper.
Secondly make sure you are using a long enough stitch.
If none of these things work.... take it in and have an example of the skipping. Have the machine's timing checked.
Oct 30, 2013 | PfaFF Creative 7570
MY 18.8 PFAFF WITH IS SKIPPING STICHES I HAVE THE QBOT
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Jan 12, 2013 | Sewing Machines
Needle continually unthreads itself
I would suggest to you to change the needle--it could be damaged
causing the thread to be cut.
also check the needle plate for burrs or sharp spots that you can feel
with your finger.
Nov 07, 2012 | PfaFF Sewing Machines
Pfaff 2144 won't stitch right side of buttonhole or skips stitches
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
Jun 11, 2012 | Sewing Machines
Needles are breaking and the machine skips stiches
Well there are many reason for that problem you may check out one by one -
1. TENSION - check out the upper tension.
2. BOBBIN.
3. NEEDLE -many times a seamstress will get in a hurry and not give the needle a second thought when putting a new one in the machine. If your machine will not pick up the bottom thread or skips stitches badly, in most cases it's because the needle is in wrong.
4. NEEDLE PLATE.
Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Jan 26, 2011 | PfaFF Sewing Machines
Zigzag not working
Download the users manual here if you don't have one. PFAFF users manual.
Nov 17, 2009 | PfaFF Hobby 4260
My pfaff hobbymatic has stopped doing zigzag and the needle is stuck on the right hand side
Check your needle position selector, it must be selected to the right position for special application. Default must be in the center position. If it doesn't want to center itself when straight stitch is selected then I would thing a link inside came loose and a repair person should assess your problem specially if having no experience working on them.
Apr 22, 2009 | PfaFF Sewing Machines
Sewing Machines Logo
346 people viewed this question
Top PfaFF Sewing Machines Experts
Irene Tulloch
Asmodius
Level 1 Expert
Chris Wetmore
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
