Question about Samsung Star GT-S5233 Cell Phone
Cannot transfer videos from pc directly to external memory, samsung star
Posted by nezybermejo on
Anonymous
  • 352 Answers
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
Posted on Jun 18, 2011
aminaso770
    New Friend:
Comment Nformati Eneti
Posted on Aug 31, 2012
Memory full on samsung star even though i have an 8gb memory card inserted
There are two types of memory engaging the phone, one is the phone memory that operates the entire phone and the other is the external memory which seems to be the memory card storage,all data especially media files such as photos,videos,musics,movies etc. must be stored on external memory so that the phone memory will not be overloaded,if all files are in the phone memory,system file might not operate properly due to full memory and it may result to phone system corruption or might shut down suddenly.
To prevent this problem,be sure all media files must stored on the external drive or memory card.If the phone is malfunctioning at this time even you do transfer all data,you need to reset the phone so the phone memory will be refreshed,by doing this,(on your phone home screen) type *2768*3855# ... this method will reset/format the eeprom or phone system,just wait for a few seconds and it will restart automatically,now your phone is back on default or original settings.
note : To perform this action,be sure battery is fully charged to avoid formatting failure.
Thank you for choosing Fixya...
2answers
How do i download music from computer to my cellph0ne GT- S3653W.
Good day. Use card reader to transfer file from pc to your phone, or if you have a cable supported from your phone package you can use it, but make sure to download the software first to your pc, so you can able transfer files without getting off your memory card. Thanks.
How to save incoming msgs in phone memory and how to transfer all msgs to memory card
You cannot save the messages on the memory card for your phone.What you can do is to transfer the messages to your pc suite.,i.e,samsung pc studio.
1helpful
3answers
How to transfer games from pc to samsung star gt s5233???????
just download any games compatible from pc and connect your mobile to pc and directly transfer files
2helpful
2answers
Hi please please tell me how do i copy or save text messages from PC To MY PHONE or other folder drive cuz i need to format my pc and dont want loose my messages ihave samsung star 3g GT-S5603
what you are looking for is a cellphone manager try this site
http://www.dl4all.com/search/samsung+star+3g+gt-s5603+PC+STUDIO.html
compatible w/ your cell
hope this help feel free to rate
3helpful
I can't save files or data directly to memory card
Samsung s3310 cannot import files to memory card directly,When we are transferring through Bluetooth.When we are transferring files through Bluetooth,it stores in default to phone memory and this memory cannot be changed to memory card memory.
There is one way to transfer large files with 500megabytes size through compression of file and splitting up to many sizes.We can use any software for compression and splitting up."ERROR MESSAGE:memory is full" can be avoided through this above way.
Why do the videos go to internal instead of external memory?
try to do this.
1. check if your memory card is formatted using your phone formatting utility. if not, back up the files on your memory card to your computer and reinsert it to your phone and have it formatted there ( don't format your memory card from pc this is not a good idea for it).this is also a cause or one of the reasons why the files, even if you save to memory card will add to your phone internal folders. the memory card needs to adapt the phone internal first before you can use them.
to answer your question,
converting videos are not only the issues for samsung, other brands and models as well. not all video codecs are supported by 1 phone. if the manufacturers will install all the codecs for a phone player, they should install first a prom that is large enough to hold them. it's never easy huh, but look on the other side, you will learn how to convert videos not only on 1 file extensions but for many. :-)
now, to transfer files, check your phone pc connection settings, do these by selecting menu, phone settings, pc connections, and enable ask on connection, at least you can select whether you want to connect it by pc suite or by memory card. select memory card, at least on that way, you will know that your are transferring and copying files from you phone memory card to your pc and vise versa. once you had formatted your memory card, you can see the same folder as you have on your phone internals. you can easily drag and drop files.
adding videos to your internal phone, i don't believe you need to do that, but for ringing tones and alarms, the phone will immediately add them to you internal folders once you had assigned them. try going to your my files folder, and check for the files, filter them by phone and memory card. you can see the drop down list at right top hand corner of your phone and check it there if the files are there in your memory card, you don't need to copy it to phone memory. you can access the files there.
just select the files and select more for more options.
regards.
1helpful
2answers
4helpful
Unable to transfer data to external memory of sgh m200
change your connection settings . Go to settings>PC connections> select mass storage.
Bluetoothed movie clips store at phone memory not external memory
Good day sir/ma'am. well normally cellphone do transfer directly to the phone memory. what you can do is to move it to the external memory manually after transferring. may i suggest you use a card reader, and use a pc to transfer files more efficiently and alot faster. bluetooth is really slow. in our company we use card readers to transfer data from cellphone or camera to pc. hope this helps. thanks
Samsung Star GT-S5233 Cell Phone Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Tim Whalen
shizznat
Level 1 Expert
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
