Question about Panasonic DMPBD65 BluRay Player
Image blurred with white dots and image not stable
Posted by stanislas_go on
  • stanislas_go Jun 18, 2011
    I still have blinking flashlight while playing the dvd
Rossiel Gomez
  • 517 Answers
Good day!
Please try to look first the nstc/pal set-up of your player that found on the rear side..
If your settings is pal please try to change it to nstc..
and if your settings is nstc change it to pal..
If the problem persist,just add a comment to proceed the next troubleshooting.
Thank you and good luck
Posted on Jun 18, 2011
Azrael SRL
  • Panasonic Master
  • 11,800 Answers
That is caused by a signal level that is too low for the tv to decode correctly.
Either the cable that is used to connect the player to the tv is damaged and it will have to be replaced or (if the cable replacement hasn't helped) the video output of the player is defective. That is something only a dealer's repair shop can fix - the replacement parts involved can't be obtained anywhere else and without them the player can't be repaired by anyone.
Cinemin swivel small light dots
Mine did the same thing and about the same tine last year. I finally took the swivel apart and got the following numbers off of the light bulb module, "L959 A1009 1564" and "FLW A1009 0787".
Tried googling the number and got nothing. Wowee says that there are not supporting the swivel and did not offer any help. cinemin-swivel-small-light-dots-hbetxv1eg5wyohukrtvklgxw-1-1.jpg cinemin-swivel-small-light-dots-hbetxv1eg5wyohukrtvklgxw-1-4.jpg
Mar 03, 2013 | Apple Cinemin Swivel Multimedia Ipod...
PROBLEM WITH LENS/ LCD SCREEN
problem with the lens,not with the lcd,the image fomation is bad,so replace the C.C.D
Mar 05, 2010 | Sony Cyber-Shot DSC-H1 Digital Camera
My InFocus IN76 just started displaying yellow and white dots.
are the dots pixelated or blurred? if they are pixelated, you have a dmd chip issue and will have to replace the whole optical engine. if they are blurred, it is an optics problem, most likely the colorwheel. that can be replaced individually. you can get parts from an infocus service center or send it in to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 18, 2010 | InFocus Office Equipment & Supplies
White dots and black on my screen
Are these dots moving with image or stationary under a moving image. This is a key identifier
Jun 23, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Colors print blurred
I had that problem too. The weird thing was if I printed in black and white, the printing was fine. For me it looks like it was a new defective photoconductor unit. When I stuck the old one back in, no problem but my old one was producing 4 color dots all the way down the middle of the page. I went on eBay and brought a re-manufactured one (buy at your own risk) and the color printing was perfect again.
May 29, 2009 | Epson ACULASER CX11NF All-In-One Printer
Blurred on right side but fine on left
Difficult to say, but it sounds like you may have somehow dislodged a mirror, or somehow contaminated the optical section. You'll probably need to have it looked at.
May 23, 2009 | Canon PC-940 Black and White Copier
The image have white blurred images in all modes
CCD Failure !
u are lucky it will be repaired free of charge from Canon even if u are out of warranty bcoz it is a known problem in CCD chips pls see the link call canon in ur region and go rate me FIXYA for help
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
Apr 10, 2009 | Canon PowerShot A95 Digital Camera
Monitor showing dots all over
Dear user,
It could be the following 4 errors:
1, Vga cable damaged.
2, Video card memory failure.
3, Lcd Panel starterd to damage.
4, The connection between the computer and the monitor is not stable, the plug is not tighten on a side it could be any sideo on the vga cable meaning you have not screwed into the monitor it can lease and fall down from the monitor.
Please check thease.
Nov 17, 2008 | Kogi L7CH Monitor
Speaker wiring
hi mat
you should have four terminals two plain and two with dots
to get the best power cut two inches off good speker wire
tear apart now place one wire from
plan black to red with white dot then
plain red to black with white dot
this is how set then up with my directed 1100d mono amp .. very loud at half gain
well hope this helps.............. ..benjaminsarmy..
Mar 29, 2008 | Car Audio & Video
Picture has a blur image
i think the problerm is not your tv but the reception on your free view
Jul 14, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Panasonic DMPBD65 BluRay Player Logo
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
