Im the owner of a yamaha c3 scooter. when i start it it will run great for about five min then it stalls. at that point it has no fule but still has spark. if it sits for ten min it will start and do the same thing.
SOURCE: 2001 Road King. Runs fine for three or four
The same thing just happen to me and a friend of mine on our 2001 Road Kings. I am 95% sure your problem is the crank position sensor. We replace ours and the bikes are back to their glory.
SOURCE: FOR Yamaha XF50 model Yamaha c3 scooter stolen ignition wires cut
Just pick up some wire connector unions with some shrink wrap.,Identify first the identical matching wire colors (each wire will have a color, example: red with a white strip connects to the other red with white strip etc.) do this to all the wires being sure to slide a length of shrink tube up over one side of the wire before crimping the connector with the two ajoining wires together then slide the tube over the wire crimp connector and use a lighter or heat gun to heat the rubber shrink tube to seal the connector. Do this to all the cut wires one at a time until all are joined together withe union crimping connector method. Be sure you positively identify the color of the wire and its backround stripe color along with the other identical wire that it needs to connect to, you don't want to hook the wires up wrong it could burn something out be caareful and positive the color patterns on the wires to be unioned are identical if you do you will be alright in this job.
SOURCE: My 50cc scooter is having trouble starting
the only way i can start my scooter is to kick start , what is my problem?
SOURCE: Harley fxstc 1999 sputters and dies after five ten min of riding
You need to check the fuel filter -- follow the fuel line from the tank down to the filter, should be tucked in below the seat..
