Gigabyte GA-8VD667 Motherboard Logo
Question about Gigabyte GA-8VD667 Motherboard
I have no graphic controller - Gigabyte GA-8VD667 Motherboard
Posted by darshitraval on
Anonymous
  • 961 Answers
This is Gigabyte's link for your board. It's shows support for Win XP and earlier. If you have upgraded to Vista or Win 7, you may not find the driver your looking for:
http://ee.gigabyte.com/products/page/mb/ga-8vd667/download/
They suggest the Intel 845/865 chipsets so, you can also try here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Chipsets&ProductLine=Desktop+Chipsets&ProductProduct=Intel%c2%ae+845+Chipset+Family&ProdId=757&LineId=127&FamilyId=40
They also show nothing past Win XP. If you have np picture, you may be able to start in "safe mode with networking", and download.
Posted on Jun 18, 2011
Sudeep Chatterjee
  • 3,267 Answers
For XP download from here
or here
How cani turn my screen when its upside down
I assume you have an Intel graphics controller.
Intel HD Graphics Control Panel
  1. Press Ctrl + Alt + F12 to open the Intel Graphics Control Panel
  2. Select Display
  3. Change the Rotation to either 0, 90, 180 or 270
  4. Select Apply
Do not know where video card is located
You have integrated or On-Board graphics which means your graphics controller is located on the mother board itself. fortunately you have a PCI-e expansion slot so you can buy a PCI-e graphics card to replace the on board graphics that is if your having graphics problems. or not if your just wanting to know where your graphics card or controller is located. Hope this helps
1helpful
Driver software for intell 82815 graphics
You can go to
http://www.intel.com/support/graphics/intel815/
This is the Intel page for the 82815 Graphics controller. Under the "Software and Drivers" you can pick the driver depending on your operating system.
Hope this helps
ATI Radeon 9550
To find the latest drivers for your ATI card, use this link I have provided
to find more info about driver updating and graphic card drivers.
make sure you download the right driver for your graphic card(graphic card name) and also download the right catalyst control center to take full advantage from your graphic card.
Good Luck.
2helpful
My catalyst control center wont work
Catalyst Control center the the graphics management software. If comes with ATI Graphics Cards. Reinstalling the display driver will solve the problem.
I have a hp presario SR5440AN and am trying to find out if i can use a pci express graphic card in it
Yes you can, if your computer has an AGP slot (advance graphic port) then it would be better to use a AGP graphics card instead on a PCI graphics card.
I can't remember if the Presario has an onboard graphics controller on the motherboard, if it has and you install a AGP or PCI graphics card, you may need to disable the onboard graphics controller in the BIOS.
3helpful
3answers
Vedio controller GeForce 6200
XFX GeForce 6200, Graphic Card
driver dowunload
Defination
from WIKI:
A video card, also referred to as a graphics accelerator card, display adapter, graphics card, and numerous other terms, is an item of personal computer hardware whose function is to generate and output images to a display. It operates on similar principles as a sound card or other peripheral devices.
The term is usually used to refer to a separate, dedicated expansion card that is plugged into a slot on the computer's motherboard, as opposed to a graphics controller integrated into the motherboard chipset. An integrated graphics controller may be referred to as an "integrated graphics processor" (IGP).
next time do some research. GOOGLE it.
2answers
Defenation of vga card
The Graphics Controller is the video card used by your computer. It is used to process the information that your screen displays. I don't know what problem you are having, but if a program is complaining about your graphics card, you may need to upgrade it.
Top Gigabyte Computers & Internet Experts
Mehandi Husain ...
MegaByteMe
MegaByteMe
Steve
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
