Question about Dell Dimension E520 PC Desktop
I have an Dell Dimension E520 Desktop and i have the DVD/CD drive for it. But for some reason, the driver stopped working, it has power still on, i can open the tray and close it, the green light also lights up when you close it, like its reading the file, but after 30 seconds the light goes out again. I've tried to find the hardware again and install new drivers, but i cant find it on hardware properties.
Posted by adhd4real on
IQUIT
  • 3,940 Answers
This fix it tool from microsoft should resolve
http://www.fixya.com/support/r6169039-cd_dvd_drive_disappears_in_windows
Posted on Jun 18, 2011
How do i install an extra SATA cd/dvd drive in my dell dimension e520 pc with attention to the correct way to connect the cables and power supply
Hello
I have found the service manual for your PC.
Scroll down to the part on how to install a new CD/DVD drive.
http://support.dell.com/support/edocs/systems/dime520/en/SM_EN/parts.htm#wp1056445
hope this helps.
Jan 30, 2012 | Dell Dimension E520 PC Desktop
My cd/dvd burner won't work. i put in a cd and a green light blinks a few times and nothing happens. My Dell is a dimension E520. thanks!
In MY Computer, check to see if the DVD drive icon is there.
Try a different DVD or CD brand
Check the sata or IDE cable connection to the rear of the drive and also the security of the power rail
Dec 28, 2010 | Dell (M6790) DVD RW Burner
Light in front comes on but nothing else
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 18, 2010 | Dell Dimension E520 PC Desktop
The CD/DVD drive will not play or burn Cds or DVDs. Just started to 'go wrong' yesterday. Its a Dell E520 running Vista Home Basic
The easitest way restore your computer several days back, or your system recovery which comes with the computer when you first purchased it.
Oct 13, 2010 | Dell Dimension E520 PC Desktop
I have a Dell Dimension E520 that has an error that is 3 lights number 1 3 4 . What does this mean?
  • Ensure that the cables are properly connected from the hard drive, CD drive, and DVD drive to the system board.
  • If the problem persists, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
  • Dell Diagnostic Lights 123 all in solid state
    Jun 17, 2010 | Dell Dimension E520 PC Desktop
    I have a Desktop comp. DELL_Dimension E520. I
    You should download the drivers BEFORE you change the OS and maybe put them on a flash drive or burn them to a CD.
    You can get them direct from the DELL site.
    It maybe that your XP disc does not recognise a SATA drive and for that reason you should use the F6 option whilst booting from the XP setup disk and point it to the CD or flash drive.
    From then on you should be able to format the disck.
    Some of the dells are a little tricky that way.
    You may also have to change the bios option as for sata type
    I have had to do this on a few dell laptops.to down grade from vista to XP
    May 28, 2010 | Dell Dimension E520 PC Desktop
    Dell software driver installation help
    http://support.dell.com/support/topics/global.aspx/support/product_support/en/product_support_central?c=us&l=en&systemid=DIM_PNT_P4_E520
    GOTO TO HE LINK AND DOWNLOAD DRIVERS NECESSARY.
    Nov 05, 2009 | Dell Dimension E520 PC Desktop
    Dvd/cd rom not working
    Are you fimiliar with the Inside of a computer box?
    Apr 03, 2009 | Dell Dimension E520 PC Desktop
    Dell Dimension E520 PC Desktop Logo
    268 people viewed this question
    Lee Hodgson
    Lee Hodgson
    efs_perpends
    efs_perpends
    Michael Thomas
    Michael Thomas
