Question about Saeco Stratos Coffee Maker, Espresso Machine
Hi i was given a coffee machine by my frein the only thing is its in german can i change the language
Posted by ourbarb4 on
bansheracer
  • 1,089 Answers
Hi You need to change your language in the menu. Push and hold the menu button. When it changes in the window, use the up or down arrow button to move the asterisk (*) until you come to a window that has something like "lingua, or spreka", and then push the menu button again. Use the up arrow to scroll to "English". When you have the asterisk (*) in front of English, push the menu button again. You have selected English and then you can push the escape button to exit. Some machines have exit in the scroll bar, so it depends on your machine.
Posted on Jun 18, 2011
Why won't it turn on?
Honestly, I've never even saw a Jura Capresso Impressa S9 Coffee Maker so excuse me that I won't provide you a specific answer, but maybe I can help you with some generic guidelines. I
According to your description, after 5 years it's presenting some problem.
About German language message, copy it to google search, between quotes and add word translate; see if you get some intelligible return.
Other trick to get a tranaslation is to send text to yoursel with gmail and select "translate"
Depending on content of that mysterious German message, probably you should look for some repair service. Maybe on your original warranty you have a listin of "authorized repair service" or the shop where you bought it can tell you where to take it.
Aug 29, 2015 | Jura Capresso Impressa S9 Coffee...
Message is in german and switches to series of numbers
Would it be possible to find someone who understands German to look at it for you? Maybe they could get it to change if they :spoke" to it in its own language.
Apr 24, 2015 | Jura Capresso Jura / Capresso IMPRESSA S7...
Change language from german french
The machines usually come with the language in the country they are bought in. You want to change the language. Once you are in the programming mode, press the up and/or down button until you come to language then press OK or equivalent. Then press up/ down until you come to the desired language and press OK. I hope this works for you, all the best Kolbrun
Sep 19, 2013 | Saeco Coffee Makers & Espresso Machines
I would like to have the display in English, can you provide the steps in doing this
Hi
If you push the menu button, the first thing that usually comes on is the language. It will usually say something like "Spracke or Lingua" which is language in german and italian. Push the menu button again to enter. Then use the up arrow to move the astric to English and push the menu button to lock it in. Then you can exit and your good to go.
Jun 02, 2011 | Spidem Trevi Automatic Espresso Machine
I was given an acer aspire one notebook but windows 7 appears to be in german how can i change this to english
The program disc loaded into this computer was in German
An English version is needed
This can not be changed by typing in anything with the German version loaded into it
Dec 20, 2010 | Acer Aspire One Netbook 8.9" Notebook
How do I change the display language to English from German?
Here is a link to the instruction manual http://dl.owneriq.net/f/f4753fec-f772-34c4-59b4-8c5d346f7941.pdf
While this other link is not your specific model, it is close and does offer instructions for changing the language that might be able to help you - http://www.kuppersbuschusa.com/Documents/Use_Care_Guide/EKV6600-0_UandC_Guide.pdf
Jun 15, 2010 | Kuppersbusch K?ppersbusch EKV 6800.0 M...
Tomtom Navigation in German Need English
Tap "Change language" button to change the language
You can choose from a wide range of languages. When you change the language,
you are also given the opportunity to change the voice.
you can download manual
go to tomtom website ----> support scroll down at the right hand side click Find downloads
20/Apr/09
Apr 12, 2009 | Tomtom Go 700 Portable GPS Receiver
Saeco on German - need ENGLISH!
go in the menu if its in german lock the word in german for language go in it select english there you go pierre
Dec 27, 2008 | Saeco Magic Comfort Plus Espresso Machine
Instruction manual for Solis Master5000 / digital
Turn on the machine. Hold down the button that says steam/enter (the one below the blue button) until it says "Sprache" and "Wasserh.." . The cursor will be blinking beside Sprache. Use the down/up arrows (the large coffee and espresso cup buttons) to scroll until you find English. Hit 'enter' (steam/enter button) to set the language to English. Hit 'escape' (the tall coffee button) and your language should be set to English. You can also go to solis.ch and download a manual for your machine. Good Luck!
Dec 15, 2008 | Solis Master 5000 Espresso Machine
Machine display changed to German
HI,
Yeah, when the machine is turned on, you click the "p" button (the descale button, actually, the one in the top right corner). This will put it into programming or selection mode. First, it will ask you about tome (or "heurs" in french, if it has defaulted back to the original language). You can cycle through a series of ssettings by pressing the button multiple times. One of the settings is the language setting, and you press the btton below the "p" button (i think it is the Large Coffee button) to choose from the different languages. When it is on english, you press the "p" button again to move on.
It sounds complicated, it really isn't.
Cheers,
Frederik
Jul 11, 2008 | Nespresso D300 Espresso Machine
Saeco Stratos Coffee Maker, Espresso Machine Logo
154 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
