Question about Yamaha Electrical Supplies
You can safely use any ul approved device using 120v 50 ~ 60 hz if you stay within the limits of it's potential (in your case 2000 watt). You will probably have a loss of efficiency using a step up transformer and will be very limited on the wattage available at the 220v. Most converters are not designed for continuous use and recommend that you buy a converter with at least 25 % more capacity than you will use. Also to get longer life out of your generator, you should use only 75 percent of its capacity for continuous use. A 2000 watt converter will work fine for loads of about 1500 watts or less.
Posted on Jun 18, 2011
Jan 09, 2015 | Samsung Televison & Video
Sep 21, 2011 | Singer 4423 Sewing Machine
Dec 17, 2017 | Craftsman NEXTEC 11812 12 Volt Lithium-Ion...
Aug 10, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Apr 06, 2011 | Yamaha DTXplorer 5 Electronic Drum Set
Apr 01, 2011 | Xantrex Technology Xantrex SW Series...
Mar 30, 2011 | Vacuums
Nov 16, 2010 | Whynter SNO ICE-100S 3 in 1 Portable Ice...
Sep 01, 2010 | Inverter Xantrex MS2000 Sine Wave Charger...
396 people viewed this question
