Breadman TR2200C Ultimate Bread Maker Logo
Question about Breadman TR2200C Ultimate Bread Maker
Every time I make a loaf of bread with my Breadman BK1060BC it comes out with some kind of black stuff on it that looks like oil or something and I don't see nothing wrong with the pan
  • Anonymous Mar 30, 2014
    doesn't start
Anonymous
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
Common issue with certain make and models spanning the last 25 years. It's nothing more than non-toxic food-safe shaft-to-seal lubricant leeching out into your finished loaf. Nothing wrong per say, and there's really no fix.
Hope this helps!
Posted on Jun 25, 2011
  • Anonymous Jun 26, 2011
    Rating our advice will let us know if we are doing you any good. Please take a moment to rate this advice. Thank you. And for all your U.S. and Canadian breadmaker needs visithttp://www.bread-maker.net/sitemap.htm
  • Doug Eddy Dec 10, 2015
    I did not have this problem in the early days of my bread machine. Can the seal be replaced?
I just purchased a Breadman Professional Bread Maker - Model BK1060BC. This is the second time I have used it and my problem is this: During the first hour of the cycle the machine is very loud and...
You may be making a loaf that has too over loaded with ingredients. Try making a 1 pound or 1.5 pound loaf next time. Even a 2 pound loaf requires no more than 4 cups of flour plus the other ingredients.
The paddle for my Breadman BK1060BC has been coming off during kneading. Today, I saw some grey residue in the dough. Is the problem with the paddle, pan or both? Thanks.
I just purchased this 2 days ago and started to use it. I noticed the bread pan would wobble and was noisy during the kneading cycle. On the second use the paddle came off during the kneading cycle. Being a service technician all my life, I started to analyze the problem. I was previously surprised how loose the bread pan fitted into the bread maker and suspected there should be something to support the pan and hold it in place. I could not see anything obvious, but after looking carefully I noticed spring clips on the bottom of the bread pan, and also mating spring clips in the bottom of the bread maker. If I pushed the bread pan down fairly hard into the bread maker the bread pan would snap firmly in place. This stopped the wobbling during the kneading cycle and the paddle coming off. I could not find anywhere in the manual where it explained the bread pan must be pushed firmly down into place until it snaps in. The manufacturer should explain this to their customers on their website.
2answers
Bread pan does not release loaf after baking.
The Teflon coating on the inside of the pan has worn. You will need a new pan and probably also a paddle. In the meantime you could try spraying the inside of the pan with cooking oil prior to each use.
1helpful
BREAD OVERBAKES
Take a look at your manual. There are a couple pages with charts showing the kneading and bake times for the machine. Try setting a cycle for a smaller loaf. I have a similar problem and had been setting a timer to take my loaf out early.
2answers
Big chunk out of loaf bottom
Unfortunately that will happen almost every time. I have the instruction booklet and it states it may even BAKE into the bread as well. No way of getting around the HOLE in the bottom of the bread.
Kneading blade won't come out with the bread
one thing that i do is i lube the shaft with cooking oil and that seems to work getting the paddle out but for nor not tearing the bread you have to remember that it is baked into it
Breadman TR875 Gluten Free Setting
 Mine won't either. I do not like the gluten free setting. If you read the times in the catalog the gf setting does not allow a rise program. I have been baking gf bread since last oct. I use the rapid cycle and all my bread comes out great.
2helpful
2answers
Error Message 1
for the breadman pro (assume the same for the 850), this means that the bread maker is too hot (likely you just finished baking another loaf)
Top Breadman Kitchen Appliances - Others Experts
David Shaub
Steve
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
