Question about LG LFX25971ST Bottom Freezer French Door Refrigerator
Everything in the fridge and drawers began to freeze about 10 months after purchase. Reducing the temperature to as high as 46 F doesn't help.
Posted by shahram_yazd on
Richard Lew
  • 489 Answers
Check the ice bank door to make sure it is closed properly. It is the door that covers the icemaker. Usually that is the problem that someone has left the door ajar leaking freezing temperature into the refrigerator.
Posted on Jun 18, 2011
My Kitchenaid refrigerator deli drawer freezes everything, how can I fix this?
Check the air flow vents for ice buildup, this happened with my whirlpool fridge. Hope it helps.
Feb 03, 2015 | KitchenAid Refrigerators
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
Fridge keeps FREEZING food in my fresh food pullout drawer!
temperature sensor is not working
this part to control the temperature in the fridge
Nov 28, 2017 | Whirlpool Gold GI0FSAXVY 19.8 cu. ft....
My ice maker isn't getting water in to make ice. I can manually pour water into the maker, let it freeze, and get the maker to get the ice out, but no water comes in. GE model GSHS5KGX. Side by side...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | General Refrigerators
Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Apr 25, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Fridge temp is set on 1 and milk and eggs are still freezing.
This is a common problem and it has to do with the electronic temperature sensor. Check with Sears to see if there is either a recall or a TSB (Technical Service Bulletin) for your model. They may try to get you to buy a new circuit board, but the solution is actually the temp sensor itself. (www.searspartsdirect.com) will give you the scematic as well as the part number. Just enter your model and press enter.
Mar 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge side began freezing everything then the fan
Generally speaking, sounds like you may have the frozen condensor problem that is so common
because of the design flaw in the Samsung products.
Turn it off, empty the freezer.
Study the back and look for formed ice around the seams.
So it got too cold, and now it is still too cold, or not cold enough ?
May 08, 2009 | Samsung RS2556 Side by Side Refrigerator
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
113 people viewed this question
Top LG Refrigerators Experts
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
